Introduction: DIY Bow and Arrow
Hello ! This is my first instructable . In this Instructable I will show you how you can make your own bow and arrow. It is easy to make. This might help you mastering your aiming skills :))
WARNING : Not suitable for children below 10 years !!
  • A long and sturdy stick for the bow.
  • A middle sized stick for the arrow.
  • Nylon string.
  • Red paint and paint brush.
  • Thin styrofoam disc.
  • cutter
Step 1:
  • Grab the long stick and make a slight cut 3cm away from the ends of the stick.
  • Make sure you make the cut on the convex side of the bow.
  • Don't make the cut too deep.
Step 2:
  • Take your nylon string and tie it in one of the cuts.
  • After tying, pull the string such that the bow bends like a 'C'.
  • While keeping the bow bent, tie the other end of the string to the other cut.
Step 3:
  • Load the arrow into the bow and check if it is working properly.
  • If the arrow doesn't travel to a long distance, the bow might not be sturdy enough or your nylon string is loosely tied.
  • Sharpen the tip of the arrow so that it can pierce the Styrofoam disc
Step 4:
  • Paint the targets on the styrofoam disc.
  • You may mount this disc on a stand or hang it from a point.
Step 5:
Please make sure you don't aim at people ! Only aim at the target disc. If you are above 10 but below 13 years of age, don't play without adult's supervision.
Have fun with the bow and stay safe !!
