Introduction: DIY Bubble Fountain
Materials Needed:
- Acrylic Sheet
- Air Pump
- Aquarium Pipe
- Blue Waterproof LED
- LED Adapter
- Wood
- Black Tape
- Spray Colour
- Hot Glue
- Super Glue
- Silicon Sealant
Tools Needed:
- Cutter
- Needle
- Drill
Step 1: LED and Piping
So Let's start...
- We need 2 Acrylic sheet of 23cm height and 2cm width.
- Attach Waterproof LED on 1 sheet.
- Take an aquarium pipe and seal one end with hot glue.
- Then place the pipe on that sheet with hot glue.
- Take a needle and make some holes on the pipe.
- Then take a drill and make a hole on the other pc of the acrylic sheet
Watch the full video on YouTube and don't forget to SUBSCRIBE and SHARE
Step 2: Colouring the Sheets
Then we need 2 more Acrylic sheets of 13.5cm height and 2cm width.
- Take the drill and make a hole on 1 sheet, so the pipe passes through.
- Make 1 more small hole just below the last hole, so the electric wire of LED passes through.
- Now colour the 4 acrylic sheets with Black spray colour.
Step 3: Assembling
Now we need an Acrylic sheet of 18cm height and 25.5cm width.
- Attach black tape on the sheet.
- Then turn the sheet and put silicon sealant.
- Take the 4 pcs of acrylic sheets and place them.
Step 4: Final Sheet
Then we need an Acrylic sheet of 14cm height and 23cm width.
- Colour the sheet with Black spray colour.
- Put silicon sealant on the top of the 4 sheets and place this sheet on it, and let it dry for 24 hrs.
Step 5: Electrical Connection
- Now take a wood and give a 2.5cm cut and place the structure on it.
- Connect the LED Adapter with the LED.
- Then take an Air pump and connect with the pipe.
Step 6: Final
- Switch on the LED and the pump
- Finally, fill the structure with water and enjoy the Bubble Fountain.
