Introduction: DIY CCG/TCG Card Dividers - Pokemon
This is a very simple one!
These are the "UltraPro" Style CCG Dividers that flip from Horizontal to Vertical.
Grab the PDF template for Pokemon at: http://kexman1775.deviantart.com/art/Full-Pokemon-...
or
Grab the Photoshop PSD file to make your own at: http://kexman1775.deviantart.com/art/Card-Dividers...
You will need:
1. A Printer
2. Cardstock or Avery Full Sheet 8.5x11 Labels
3. Scissors/Kitchen Shears/X-Acto Knife/Rotary Cutter
4. Possibly Glue if you print on paper and want to apply to heavier material.
Step 1: Step 1: Print Your Files
Grab those Templates you downloaded.
Print them in Portrait Orientation with no scaling on 8.5x11.
Step 2: Step 2: Prepare Your Material
Now, either glue your paper down on heavier card stock or cardboard if desired.
*My recommendation* Print the templates out on Avery Full Sheet 8.5x11 Label Sheets. Then cut around leaving about 1/4" on all sides. Peel off the backs and stick onto Poster board, or onto Black Artboard (This stuff is really sturdy and thick. A Large Sheet costs $6.99 at Jo'Ann's Craft Stores and can be found in the poster board section. It's solid board, very similar to the Photo Matte used in picture frames.) I stick mine on the white side so that the Black Side of the board is the back of the divider.
Step 3: Step 3: Cut Your Dividers
Cut your dividers on the black lines.
If you used the Art Board that's really thick, use a ruler and rotary cutter to get clean straight edges and then finish using Kitchen Shears.
Step 4: Step 4: Enjoy!
Sit back and enjoy your awesome dividers!!
