Introduction: DIY CO2 Airgun - Arrow Shooter - the German "Pfeilwurfgerät"
a homemade extreme powerfull co2 airgun arrow shooter from germany
Step 1: A Bullpup Airbow Powered With Co2
Inspired by Bullpup sniper Airbow from so in slingshotchannel I developed this device. The key features should be: the device must be legally! compact but relatively simple effective construction, homemade arrows brasses, simple and quick to load. Because I did not want sweat to build with a manual pump the pressure I thought very quickly to small caps co2. The pressure in a CO2-capsule such amounts to approximately 60 bar. This is extremely powerful. The main components come from the plumbing shop. What is needed is a solenoid valve. the solenoid valve presses the pressure abruptly in the arrow tube.
Step 2: The Construction
The sequence of the structure: co2 adapter -> Hand Valve -> pressure chamber -> solenoid valve -> dart pipe. The co2 capsule is screwed into an adapter which has a 1/2 inch connection. these adapters are available for paintball weapons for little money on eBay. the battery for the solenoid valve is in the grip of a toy pistol. Important: users must install a safety switch, so you do not trigger provided from while someone else or hurt yourself or kill !!! the gun barrel in Germany must have a barrier so that no balls can be fired!
