Introduction: DIY Compact Stereo Amplifier
About: Hi, I'm Steve! I'm a creative mind with a knack for technical skills—I can build just about anything you can dream up! From innovative projects to captivating designs, I bring ideas to life with passion and pr…
Hey! everyone My name is Steve.
Today I'm going to show you How to Make 60 Watt Portable Amplifier in a Very Simple Way using TDA2050 ic it is a very popular ic you can find in many home theatre system it can provide a maximum power of 30 watts at 4 ohms It needs a dual power supply 24 0 24, In this project I've used 2 of it
Click Here to See The Video
Let's Start
Step 1: Features
Output Power
  • 30 Watt x 2 @ 4Ohms
Input Power
  • 16 - 24V DC
Built-in Protection
  • Over Load Protection
  • Short Circuit Protection
  • Over Heat Protection
Note - Please see the images for better understanding
Step 2: Thing I've Used
LCSC
Banggood
Amazon
Aliexpress
Step 3: Circuit Diagram
You can see the circuit diagram to make it easier
Step 4: Sponsor
Today's Article is Sponsored by lcsc.com
They are the Largest Electronics Components Supplier From China Ready to Ship within 4 Hours and they ship World Wide
Step 5: PCB Board Designing
I Used EasyEDA To Create my PCB Using the Circuit Diagram Provided by STMicroelectronics and it took me about 2 Hours to Design
You can see I've used XT30 for Speaker output for easy plug and play
You can Download the Gerber Files
Gerber & Circuit Diagram - http://bit.ly/2X15vQG
Step 6: Ordering the PCB
Nowa Days it has been very easy to order PCBs and it doesn't cost you much, Yeah you easily do this in a Perf Board but the PCB Looks way better then Perf Board and Very Safe to Work So You can Put little work and money to get Professional Results
For This Project, I've used PCBGOGO Service for Manufacturing my PCB and it took about 24 Hours to Manufacture my PCBs and within 7 Days they Delivered it to my door Steps And the Quality is Just Amazing
Step 7: Soldering
I gathered all the components and soldered all the Resistances first, and then Soldered the Capacitors According to the Circuit Diagram and used a Cutter to cut all the extra legs
And then I've Soldered the XT30 Connector
After That, I've Soldered the Main Ic TDA2050 it took me about 30 minutes
Step 8: Stands Off
I used 4 stands off to give it some clearance
Step 9: Heat Dissipation
I've used a Decent Size Heat Shink for Heat Dissipation it is very necessary to use a Heat Shink Otherwise You'll burn the Chip
And it is very important to use a good quality thermal compound for better heat flow
I applied a little quantity fo thermal compound to TDA2050 IC and tighten it up with heatsink
Step 10: Power Supply
I used 2 SMPS each 24V @ 6 Amps giving a total of 48V @ 6 Amps
The SMPS is Connected in Series " It's Called Daul Power Supply "
+24 - 0 - 24 V
You can also use a Transformer Based Power Supply no issues with that
Step 11: Setup and Enjoy
First I've connected the Speakers with XT30 Connector
Second I've connected the 3 Power Supply Cable to the dual power supply
Third I've connected the 2 audio input cable via male header
How just power on the power supply and play the song "Enjoy"
Power Supply
  • Negative - Black Cable
  • Ground - Green Cable
  • Positive - Red Cable
Source Input
  • 1st Male Header - Right Input
  • 2st Male Header - Left Input
Speaker Output
  • 1st XT30 Connector - Right Speaker
  • 2nd XT30 Connector - Left Speaker
You Just Made It
Thank you for visiting my Instructables Stay tuned for next Projects
