Introduction: DIY Decorating With OLED Light Panel
Christmas is only a couple months away!
This is a step-by-step introduction of how to make a Christmas Decoration Lighting with LG Chem OLED light panel!
I hope you enjoy it!
Step 1: Prepare 9 Rectangular Wooden Panels
Prepare 9 rectangular wooden panels of equal dimensions (100x240mm)
(Note: Darker brown panels are MDF 3T and lighter brown panels are Wood, Radiata Pine Solid 24T.
Ignore the square at the center for now)
Step 2: Cut Out the MDF for OLED Light Panel!
Cut out B and C panels according to the shown dimensions.
Then, glue all B panels on top of their respective C panels.
Step 3: Paint the Surfaces
After you've made the following four thin panels with MDF, paint their surfaces in white.
Step 4: Install the LG Chem OLED Light Panel!
After drying the paint, make a wire exit-hole on the window panel's corner.
Attach Lg Chem 200x50mm OLED light panel then organize the wires accordingly.
Double-sided tape is more than enough to attach the OLED light panel on the MDF since it is very thin and light!
Step 5: Drill a Cable Exit Hole
Form the following four blocks by gluing each white panel on top of each A panel.
Drill a cable exit-hole at the center of the third block, then join the OLED light panel's wires' end together.
Step 6: Put Them Together
Glue the four blocks' ends together as shown in the center image of step 1.
Step 7:
Enjoy your early Christmas Decoration Lighting with LG Chem OLED light!
Christmas is only two months away! It is never too early to get ready for the biggest holiday around the globe!
You Create, We Light. LG Chem OLED light.
