Introduction: DIY Easy Comfort Crochet Hooks
This is a really easy way to make your regular aluminum or plastic crochet hooks into comfort grip hooks by using pencil grips. You can find them in many large chain stores like Walmart, Target, dollar stores, office supply stores, etc. This is a great idea for someone who has sensitive hands (arthritis, carpal tunnel, etc.) as well as for kids.
Step 1: Getting the Grips to Stay On
Wrap your hook handle with masking tape up to the thumb rest (the flat oval in the middle). Depending on the size of the hook you may need to wrap it only a few times or lots of times. I had to wrap my F and G hooks with a lot of tape to get them to the correct thickness in order to keep the comfort grips from sliding off while in use.
Step 2: Slide the Comfort Grips On
When you think you have enough masking tape, rip it and flatten it down. Test to see if it is thick enough by sliding one of the comfort grips on. If it slides on too easily you will need more tape. You want the grip to have some resistance so that it will stay on when the hook is in use. I used 2 comfort grips per hook so that the entire handle up to the thumb rest was covered. I had enough to do 10 hooks from one package of comfort grips. Check out my new sparkly hooks!
