Introduction: DIY Easy Lemonade Drawing
About: I am a gymnast and gymnastics is my life. I hope to go to the Olympics one day. I have a wonderful little brother too
Hello! Do you need help making a picture of lemonade? Well you’re at the right post!
Skinny Black Marker
Yellow Pencil
Yellow Crayon
White Office Paper
Step 1: Outline
You will use the black marker for the outline and the handle.
First, you draw two straight lines like in the picture. Next, on the top, you make a line curving downward. And then you make a line curving upward connecting to the curvy line you just drew. This will be the top of the glass. Then, on the bottom, you will make the downward curving line. Now to make the handle! For this you need to make a large sideways U like in the picture. Then make a slightly smaller U inside it. Now you have your cup!
Step 2: Ice (optional)
If you want ice in your lemonade, then you can make some! You will use the black marker again for this step. You can make ice by making slightly tilted squares. You can have as much as you’d like!
Step 3: Lemonade
Next you will make the lemonade. If you added ice, you will lightly color it in with the pencil. Now, you will make the lemonade by coloring in the cylinder of the cup with the crayon. You can use my picture as a reference. Now you are done!
