Introduction: ♡ DIY Fairy House Lamp Using Jar ♡
Hello! In this tutorial, I show you how I made a medium-sized fairy log house using a coffee jar, aluminium foil, hot glue, paper clay and acrylic paint. It’s fun to make and you can use it as a decoration, secret hiding spot, or you can even turn it into a lamp by adding some battery operated LED candle lights.
Materials and tools :
One empty jar with lid,
Aluminium foil: Link
Paper clay: Link
Hot glue,
Acrylic paint: Link
Hot glue gun: Link
Clay sculpture tools: Link
Step 1: Cover With Paper Clay
First, I cover the jar with paper clay (I used "Das modelling material" but you can any paper clay or even a homemade paper clay). I don't use natural air dry clay, it will shrink and that will result in a lot of cracks around your jar.
Step 2: Building the Base of the House
Secondly, I cut the carton to two circular shapes (or three depending on the desired thickness) and I glue them using hot glue. Afterwards, I cover it with clay.
Step 3: Adding Mushrooms and Other Plants
And still using paper clay, I added mushrooms and other plants. Also, I add an ax and trunk of a broken tree. With the same way, you can easily add more details using paper clay.
Step 4: Building the Roof of House
I used aluminum foil and glue with the lid of jar to build the basic shape of the roof. I covered them with paper clay while adding a roof window. After, I covered everything by posing above already prepared autumn leaves.
Step 5: Paint
I used acrylic paint for painting. You can also use watercolors and watercolor crayons. It's up to you. In the end you can seal the paint using some matte spray varnish. I placed some battery LED lights under the house. I recommend you use soft lights that will gently illuminate your windows so it looks like a real house.
