Introduction: DIY Fully Automatic WiFi Router UPS With Dual Output
Hello Everyone in this instructable I am going to show you all how I made this powerful Fully Automatic wifi router UPS with Dual DC output for router and Modem
Parts purchase Links:
1. 8 x 18650 Li-on Battery 2500mah (Battery I used)
https://robu.in/product/orange-icr-18650-2000mah-25c-lithium-ion-battery/
2. 18650 Li-on Battery Holder
3. 3mm Acrylic sheet
4. PCB standoff
5. 4S 30A BMS
https://robu.in/product/4-series-30a-18650-lithium-battery-protection-board-14-8v-16v-with-cable/
6. XT 60 Male and Female connectors
https://robu.in/product/female-xt60-connectors-1pcsbag-genuine/
7. XH-604 Charge Controller Module
8. 24V 3.2A SMPS
9. Li-on charger module
10. Power off protection relay YX-X804 12V-48V
11. DC-DC Boost Buck Adjustable Step Up Step Down Automatic Converter XL6009
12. DC-DC 7-28V to 5V 3A Step Down Power Supply Module (Mini Buck converter)
13. XL4015 5A DC-DC Step Down Adjustable Power Supply Module Buck Converter
14. M3 X 8 mm Brass Heat Set Threaded Round Insert Nut
https://robu.in/product/m3-x-8-mm-brass-heat-set-threaded-round-insert-nut-25-pcs/
15. 12V mini Cooling Fan
https://robu.in/product/12v-3010-cooling-fan-for-3d-printer/
16. Mini Size SPDT Slide Switches On-Off
17. AC Power Socket
18. Fuse Holder
19. Fuse Kit
20. 1N5822 Schottky Barrier Diode
https://www.electronicscomp.com/1n5822-schottky-barrier-diode?search=1N5822%20
21. 5v Relay module
Step 1: Part 1 Video
Part 1 - Video Making and Testing
Step 2: Part 2 Final Video
Part 2 - Video Final Testing and all Solving issues
Step 3: Circuit Diagram
Step 4: 555 Trigger Timer Circuit
Alternate idea for BMS reset switch to reset BMS after over discharge protection,
Not recommended to use this 555 Timer circuit.
Step 5: Disclaimer
⚠️ Disclaimer: Warning - Lithium or any type of rechargeable batteries can catch fire or explode if mishandled. Handling a Lithium battery requires a more than a basic understanding in electronics. We are not responsible for any kind of damage or loss, do everything at your own risk.
