Introduction: DIY Globe Planet Soldering Project Kit, PEMENOL Soldering Practice Electronics Kit
The finished project is a led rotating Ballerina Girl music box, after turn on the switch, the ballet girl pirouettes on circular stage to enchanting music and shimmering lights.
It is a very interesting DIY electronic product which enables users to understand the circuit more clearly and learn soldering skills.
For Detailed Information: https://shorturl.at/fG8y7
Product Link: https://shorturl.at/fG8y7
Feature:
1>.Colorful LED Lighting Effects
2>.Built-in 3 Music
3>.Rotating Stage; Rotating Speed Adjustable
Parameter:
1>.Work voltage: DC 5V
2>.LED Color:Yellow/Red/Blue/RGB
3>.Power Interface: DC-005
4>.SW1 Music Switch: Toggle to play 3 music in sequence. When turned off and restarted, the music will start playing from the beginning.
5>.SW2 Motor Switch: Toggle the switch, the stage begins to rotate.
6>.R1 Potentiometer: Controls the rotation speed.
Use Methods:
1>.Connect USB Power Wire to provide working power.
2>.Switch Toggle Switch SW1 to turn ON/OFF music playing function.
3>.Switch Toggle Switch SW2 to turn ON/OFF rotation function.
4>.Rotate the potentiometer to change the rotation speed.
Step 1:
It uses springs to connect different PCB internally to provide power, so the springs produce noise when rotating, which cannot be avoided.
