Introduction: DIY Happy Gilmore Hockey Stick Putter
About: Thanks for Viewing
  • BuildingandBlogging
This is DIY on How To make your own Happy Gilmore Hockey Stick Putter.This putter is fully functional and just awesome. It was made with common tools, and didn't cost that much to make.
This is great to have in your bag everyone comments on it. People want to try it out, take pics of it, and seem to really like it. This has a flat head on it so it can be used as left handed or right handed. I've seen people sell these for over a hundred dollars. Following this blog you can make your own.
I played both hockey and golf and years after seeing that movie I had both the putter and mini hockey stick out and decided to go ahead and make it. Keep in mind that if you have this in your bag it does count as a club if you are serious lol. This putter is full length for adults but kids do enjoy using it and is easier for them to hit the ball cause it's bigger.
If your interested in more cool blogs from use check us out here:
visit us at our Blog- http://www.buildingandblogging.com/blog
Subscribe on Youtube- https://www.youtube.com/channel/UC8LWFj1LG9vuqZBNn...
We also sell the projects we make-https://www.etsy.com/shop/BuildingandBlogging
Step 1: Tools and Supplies
For more information visit my website also buildinganeblogging.com
Tools:
Hack saw- to cut putter head- Use a metal cutting one with small teeth
tape measure-measuring everything-They come in different lengths
pencil-marking cuts-I like to use good drafting pencil's for making
drill-making holes for handle-A good cordless drill is a must for Projects
drill bits- drilling holes-make sure to get good bits
a few other common tools-Amazingon for any tool
Supplies:
old putter-Here's an example of one
old mini hockey stick-Will only use bottom end of stick
gold paint-I used metallic gold paint
painter's tape-I get it in bulk to always have around
bolts and nuts-Length may verrie I used 1 1/4 inch
I prefer to order my supplies online when I can, but also use thrift store, garage sales, dollar store, craigslist these are some example on amazon
Step 2: Visulalzing
Look at the putter and mini hockey that you are going to be using to make it.Could make the head of mini hockey stick yourself by using anything that can cut into hockey stick shape.
Its the one used in this movie here.
Make sure the mini hockey stick is a flat blade. Mine is a fiber glass type material. When it comes to the putter many are different at the heads but there's a type that you see a lot that you can find at many thrift stores. Look at the picture to see what kind I used.
Go to the actual blog for more pics, vids and gif's
Line them up together to see what kind of angle you will want the head of the hockey stick to be at so when you attach them they will line up.
Step 3: Cutting
Before cutting make sure know how it will be mounted make measurements make marks, always double check you measurements and marks before cutting.
Stress Free Golf Swing
The first cut is pretty easy this is just cutting the putter head off with a hack saw toward the end so there is enough room to mount it to the mini golf hockey stick head.(SEE PIC) Simply cut the putter head off with a hack saw.
Monster Golf Swing
Now cut the mini hockey stick so that when mounted on the golf handle it will sit right at a good angle for putting. I cut this with a jig saw. You can make the hockey stick part out of metal or wood.
Be in Golfing Shape
I happen to have this fiber glass one around. Make sure the hockey stick blade will line up with putter handle and cut off the blade.
Simple Golf Swing
As always with cutting make sure to sand down any lose materials that you cut.
Step 4: Drilling
Once they are sanded down drill holes in both the golf club handle tip and the mini hockey stick blade. To do this make sure that they are lined up in the correct spot to drill them. Us a pencil or marker to mark where the holes will be drilled. This will include drilling four holes total, 2 on the putter handle and two on the hockey blade. This could be mounted differently this is just how I mounted this one.
Please be sure to join our or builds email lists to get our latest builds
These holes can be drill out with a power drill, if using a power drill make sure to make straight drill holes. Otherwise could use a drill press to drill them. The diameter of the hole drilled was .25 inch so this will determine what size nuts and bolts will need to fit threw the holes.
After drilling out holes make sure to sand and clean up the holes. Since your are drilling threw metal it can have metal shavings. Be patient when drilling threw metal and use the correct bits..
Step 5: Attaching
This is a good thing to know even before drilling you holes or planning a project for that matter. Since in the last step we used a .25 inch drill bit to make the holes, we will be using a bolt that fits in that hole the same size, or just smaller. If you use to big of a hole and bolt it wouldn't be big enough on handle.
To save time always have- NUTS AND BOLTS ORGANIZER-
So if you have the right width of the bolt will get the corresponding nut to go on bolt you will need to get the correct length. This can be different depending on width of putter and blade. I used 1.25 inch length bolt and used two of them total sticking them threw both blade and golf handle. Keep in mind which side of the putter you want the nuts on.
Step 6: Painting
Once you have the hardware all mounted how you like it, painting it gold give it that final cool looking putter. Painting this is pretty straight forward as it comes to painting. I would not sand the metal handle, but I would spray it with primer before painting with gold.
The best way to paint this is to use painter's tape to cover anything you don't want painted gold. Since this an odd shape I used string to hand it up from the ceiling so that it could hang freely and spin to paint it. I would add a couple coats of spray paint.
Also another thing to do when painting is to add clear coat after the paint has dried. Adding clear coat will keep the Hockey Stick Putter from getting scratched. I used all spray primer, paint and clear coat.
You can watch the video on making it here also
Step 7: Summary
Lastly you want to add the finishing touch, which is adding the black patch to blade head of the hockey stick. Make sure you put it on the side for right or left hand or both.
I actually used velcro that works great. It give the club head some give when making a putt. This is used by placing your hand half way down so you are both doing a golf slash hockey swing. I don't use this as my actual putter but it does work as one. I have made ten foot putts with this.
Thanks for reading if you have any tips or suggestions for me please let me know. Also if you make one yourself post it below!
We have ten other golf related builds at the bottom of the blog
