Introduction: DIY Longboard Renovation (graphics and Grip Tape)
After moving countries and leaving my longboard behind I needed a cheap replacement! I was inspired by another couple of instructables that I could re-do the graphics and grip tape myself -spending little to nothing.
Hopefully this helps other people, especially females that aren't perceived usually as good at DIY!
Any questions feel free to ask
Happy skating
Happy skating
Step 1: Take Off Trucks
Take off the trucks using a spanner and a screw driver
Step 2: Get Rid of Old Grip Tape
This was a lot easier than I expected!
Peel up around the edges of the grip tape using a Stanley knife so it is peeled away from the board by about 1cm all the way around the edge of the deck. Then at the back of the deck start using the Stanley knife to get under the grip take even further and peel it up enough to get hold of it with two fingers. Then pointing a hairdryer down at the board, (mind your fingers) melt the glue by holding the hair dryer on the tape for about 5 seconds. As you do this pull on/peel up the grip tape using the other hand (see picture). It takes some co-ordination but was really quick and a lot easier than a lot of tutorials told me.
Step 3: Sand Down Old Graphics
Don't let anyone tell you that you can't do this by hand you can!
This takes a while and probably took me about 7 hours but that's fine I didn't want to buy a sander!
Start with a courser sandpaper and work towards a finer one.
I would have spent about 3 dollars on one sheet of course and one sheet of finer sandpaper if I hadn't found some in the shed.
Step 4: New Graphics
It is a big relief when all your old graphics are gone!
I suggest adding new ones before the grip tape as it will be easier to move your board if it doesn't have the tape yet.
For the board I used a cheap version of Posca pens (Uni ball paint pen), drew round some mugs and plates to get the shapes and went for it! Afterwards I used some wood waterproof varnish to seal it. I also varnished the top of the deck to make it look better.
Step 5: New Grip Tape
Here I spent ages looking for clear grip tape which isn't as common as I think it should be as it is much more aesthetically pleasing!
To apply the grip tape I simply peeled off one small end of the sticky back plastic cover and stuck it on the front of my board. Then, carefully I peeled the rest back and at the same time pressed it firmly onto the board (Kind of the reverse of getting rid of old tape, requires both hands doing different things).
Then comes the worst bit - trimming the tape to fit. I read that you could score the tape and then easily cut it with a Stanley knife but the scoring didn't work too well. I took about two hours care filling just cutting it to size using a Stanley knife.
Sorry for the lack of photos but I found this very tricky and stressful and forgot!
Step 6: Put It Back Together and Admire!
Ideally buy new wheels to finish it off (I clearly didn't !)
