Introduction: DIY Milling Machine Homemade 3D Printer Tools
More in my web https://3d4diy.com/
3D Printer DIY Acrylic CNC Router Machine Aluminum Homemade, Hello, I really like to make things at home using machines, but industrial machines are expensive so I make them all at home. I make mini Lathe, Milling machine, Drill press, 3D printer, Saw, Grinder, Mini CNC, Rotary Tools, Airbrushes & Compressors, Bench Tools and Shears, Laser Cutters, Drawing Plotter, Machine Tools, Soldering and Electrical, Wood Working, Vise Clamp, Power Tool Accessories and more with used materials like.
All machine good worker,
Thank for watching my video !
I really like to make things at home using milling machines, but industrial machines are expensive so I make them all at home.
Step 1: DIY X Axis Slide
Material DIY X Axis Slide:
1 20120 aluminum extrusion profile wall thickness 3.0mm groove width 8mm length 350 mm.
1 20120 aluminum extrusion profile wall thickness 3.0mm groove width 8mm length 180 mm.
4 pcs lot LM16UU Linear Bushing 16 mm CNC Linear Bearings for Rods Liner Rail linear shaft parts.
2 pcs Optical Axis Linear Shaft Rail 350 mm Smooth Rods 16 mm 3D Printer Parts Chrome Plated Guide Slide.
T 10 Lead Screw Trapezoidal Rod Lead 10 mm Length 350 mm With Copper Nuts used.
Step 2: DIY Y Axis Slide
Material DIY Y Axis Slide:
1 20120 aluminum extrusion profile wall thickness 3.0mm groove width 8mm length 380 mm industrial workbench.
4 pcs lot LM20UU Linear Bushing 20 mm CNC Linear Bearings for Rods Liner Rail linear shaft parts.
2 pcs Optical Axis Linear Shaft Rail 260 mm Smooth Rods 20 mm 3D Printer Parts Chrome Plated Guide Slide.
T 10 Lead Screw Trapezoidal Rod Lead 10 mm Length 200 mm With Copper Nuts used.
Step 3: DIY Z Axis Slide
Material DIY Z Axis Slide:
4 pcs LM12UU 12mm Linear Ball Bearing Linear Bushing CNC parts Linear Bearings LM12
Trapezoidal Rod T8 Lead Screw Thread 8mm Lead 2 mm Length 220 mm with Brass Nut
2 pcs 12mm OD Linear Shaft Length 200 mm Cylinder Liner Rail for 3D Printer Axis CNC Parts
2 pcs C-Beam Linear Rail 4080 clear anodized without cratch Al6063 aluminum Length 160 mm
