DIY Pocket Hole Jig (Easiest Way Possible)
14K132
Intro: DIY Pocket Hole Jig (Easiest Way Possible)
The absolute easiest way to make your own pocket hole jig is to borrow one from a friend and build it using this method. This is super simple, cheap, and can be built very quickly. Be sure to check out the video if you need help along the way!
STEP 1: Find Two 1x2s at Least 12” Long
I recommend using hardwood for this, but I’m sure pine would work.
I made mine out of some oak and walnut I had lying around.
I recommend using oak if you have it.
STEP 2: Set Up Your Pocket Hole Jig
Removed the stop block from the pocket hole bit (or just use a normal 3/8” drill bit)
Then set the pocket hole jig for 3/4” material
STEP 3: Drill 2 Pocket Holes
Clamp your pocket hole jig onto one of the 1x2s and drill two pocket holes in one side of ONE of these pieces.
Take your time and make sure your bit goes into the wood nice and straight.
Also, you DO want to drill all the way through the material.
STEP 4: Cut the 1x2 Without Pocket Holes to 6” Long
STEP 5: Cut the 1x2 WITH Pocket Holes
Cut it FLUSH with the back edge of your pocket holes
STEP 6: Glue the Two Pieces Together
Use wood glue to attach these pieces.
The small piece with pocket holes should be on top.
The side with holes should be flush with the side of the 6” pieces
STEP 7: Clamp It Down and Drill Through the Longer Board
Once it dries:
Clamp the pocket hole jig down and follow the two original pocket holes through the bottom of BOTH boards with a 3/8” drill bit.
STEP 8: Make the Holes Larger Using a 1/2” Drill Bit.
STEP 9: Install Your Metal Pipe
Install your 3/8” ID/ 1/2” OD metal pipe inside of one of the pocket holes.
It should be flush with the inside edge of your pocket holes on the bottom of the jig.
I used this pipe from Amazon (It’s about $15, but I will be using the rest of it to make a dowel joinery jig too)
(This is an affiliate link. I make money if you use this, but it doesn’t cost you extra)
https://www.amazon.com/gp/product/B01IRVK1D4/ref=a...
STEP 10: Cut the Pipe Flush With the Front Edge of the Pocket Hole Jig
Then remove the cut piece
STEP 11: Epoxy the Two Metal Rods Into Place
Use an epoxy to install the metal rod you just cut out and the leftover piece into the other pocket hole.
Once again, the edge of your pipe should be flush with the inside edge of your pocket holes on the bottom.
Then allow it to dry.
Here is the epoxy I used: (This is an affiliate link. I make money if you use this, but it doesn’t cost you extra)
https://www.amazon.com/gp/product/B001Z3C3AG/ref=a...
STEP 12: Mark the Bottom of the Jig
Make a pencil mark 1 3/4” from the inside edge of the pocket holes towards the front of the pocket hole jig
STEP 13: Mark the Side of the Jig
From the previous line, draw a line on the side of the jig that runs perpendicular to the metal tubing. (It doesn’t have to be perfect)
STEP 14: Cut the Line
I recommend a hacksaw to cut this. Things looked a little Smokey when I used my chop saw
STEP 15: Cut the Bottom 1x2 So It’s 4” Long From the Front
(Please cut the back side, not the side you just worked really hard on)
STEP 16: Sand It
I used a 60 grit then a 120 grit
STEP 17: Finish It (if You Want)
I just used a clear lacquer to make it look nice
STEP 18: Test It Out! It Works Great!
Thanks for checking out my bit! Check out my YouTube channel for more cool builds!
https://www.youtube.com/c/DIYMAN
2 Comments
Haha you must use a pocket hole jig to build a pocket hole jig! I love it! Just like you can't build a clamp without clamps. That being said, your method makes it very easy to build and it's nice to have several backups around the shop (I always seem to misplace the tool that I need :) ) Nicely documented!
Yeah, it’s a little bit of a “chicken before the egg” build, but I thought it was a fun build. Thanks for the feedback!
