Introduction: DIY Poro Box From League of Legends
About: Ha! Made you visit my profile!
You will need:
2- Bottle Caps;
8- Toothpicks;
2- Can Tabs;
Cotton;
Toilet paper/Napkins/Journal;
1-Scissors;
1-Craft Knife;
Watercolors;
2-Keychains;
White glue;
1- Juice Package;
1- Ice Cream stick;
2- Corks.
Step 1: Making the Box
Take the scissors and cut the Half-Top and Half-Bot of the package.
Make 2 Holes on each half as the image shows and fit each Keychain in one of them ( It's important that the holes stay all aligned ) .
Step 2: The "Skin".
Pull out the Keychains and fill the box with toilet paper and white glue.
When it dry , to find the holes put then against the light and you will find them.
Once you found them , open the holes with a needle and re-fit the Keychains.
Step 3: Pasting Cotton.
Once you're done , start pasting the cotton all around the box with white glue.
Step 4: Making the Eyes.
To make the eyes , take the Can tabs and , using the white glue , fill them with toilet paper and let them to dry.
Step 5: Making the Paws.
The Corks must be the same size , but you should need only one.
Take the Cutter and cut 4 round pieces of corks and repeat the same process as the previous step.
Step 6: The Tongue
The Process will be the same for the tongue. Use the Cutter or the Scissors to cut it.
Step 7: The Horns
To make the horns you'll have to use a needle to make some holes on the bottle caps ( I made 8 ).
Then take the toothpicks and stick then in the holes and cut the edge of the bottle caps with the cutter or scissors.
Wrap the toothpicks with a piece of toilet paper and use white glue to paste it on them , once you've done it , cut the tips of the sticks with the scissors and let the horns dry.
Step 8: Painting.
And now all you have to do is to paint the eyes , the tongue and the Horns using the Watercolor.
Note: I didn't really knew what kind of color are the Poro's horns so I mixed the dark blue with the brown color to make it similar to the original ones.
Step 9: The Final Touches
And now you just have to put all the pieces togheter and there you have your litte Poro Box ! :)
You might find some languages errors , I am really sorry , I'm still learning the english but I did my best to make you understand this tutorial .
Thanks you all ! :)
