Introduction: DIY Potpourri Steamer Pots! ~ Simple DIY Project (made With a Single Can!) - Full Instr.
About: hi there. on this instructable channel i'll be covering all types of DIY solar power projects (as well as off-grid/survival/green living projects) that are easy to make out of readily available products and ma…
in this instructable i'll show you how to make potpourri steamers just using a single metal food/soup can and a tea light (small candle). it couldn't be easier and they work great.
Step 1: Watch the Instructional Video...
watch the video either before (or after) you read the steps. video shows all the "real time" cuts for a simple and quick build plus extra footage of the steamers in action
Step 2: Read the Description...
DIY Potpourri Steamer Pots! - Easy DIY w/full instructions. the whole thing is made with a single recycled steel (food/soup can)... and a tea light (candle). video shows 5 different ones made with 2 sizes of cans. the pluses and minuses of each are discussed in the video. *great simple re-use of an old can. note: if making, make sure to use the "pop-top" style can.
Step 3: First Gather Materials...
1.) empty (and clean) metal food/soup can. (important: only use the "pop-top" style food/soup can.) see pic above
2.) a tea light or small candle
3.) only tool needed... tin snips
Step 4: Start by Cutting Down (shaping) the Can...
start by making 3 cuts to the can as shown in pics above and then bend down the tabs
Step 5: Break Off the Tabs...
to break off the tabs just rock the tabs back and a few times. it'll break in a straight line
Step 6: More Cuts to the Can...
3 more cuts to the can and then go around in a circle (that will leave you with 2 pieces)
Step 7: Now Cut Off the Excess and Assemble the Unit...
make some final cuts and assemble the unit as show above. to see all the cutting in real-time just watch the vid.. it's quick and shows all cuts in great detail.
Step 8: Optional Step...
if you are concerned about the sharp edge, either file it down or bend it over (shown in the pictures above)
Step 9: Now Just Add Your Favorite Liquid Potpourri...
i made a bunch of them. just add liquid potpourri and slide a tea light under the unit. after a few minutes it will start steaming and the air will be filled with the fragrance. there are 6 photos of the steamers "steaming" above (but to get the real feel of it, check out the video)
Step 10: Here's a Few Extra Pics ~
