Introduction: DIY Screwdriver Light
Today, we are is going to be making a DIY screwdriver light. Since Father's Day is coming up I wanted to make something for my dad, so I chose to make the tool he uses most, the screwdriver and make it better.
Step 1: Step 1: Items
Items you need: Wire Cutters, Long screwdriver, Small Flashlight, Pliers, Duct tape, Strong metal wire [I used conduit]
Step 2: Step 2: the Wire
Now rap the wire around the bottom of the metal part of the screwdriver. Don't put it on to tight, make it a little loose.
Step 3: Step 3: the Flashlight
Now, put the flashlight on the wire.
Step 4: Step 4: the Tape
Rap the tape around the flashlight to where it won't fall off the wire.
Step 5: Step 5: DONE
Now that you have made it. You may now test it, if you failed to make it loose enough but not to loose at step one. The flashlight should go up then back down when you turn it. I hope your father will like it.
