Introduction: DIY Z Axis Slide and Spindle ER 11 Milling CNC
More in my web https://3d4diy.com/
3D Printer DIY Acrylic CNC Router Machine Aluminum Homemade, Hello, I really like to make things at home using machines, but industrial machines are expensive so I make them all at home. I make mini Lathe, Milling machine, Drill press, 3D printer, Saw, Grinder, Mini CNC, Rotary Tools, Airbrushes & Compressors, Bench Tools and Shears, Laser Cutters, Drawing Plotter, Machine Tools, Soldering and Electrical, Wood Working, Vise Clamp, Power Tool Accessories and more with used materials like.
All machine good worker,
Thank for watching my video !
I really like to make things at home using machines, i need a Spindle but industrial machines are expensive so I make them all at home. I make spindle by my 3D Printer and ER 11,775 motor 12v DC
More and more DIY Projects here:
Step 1: DIY Spindle ER 11
DC 12V Motor 775 double Ball Bearing Large Torque Low Noise.
Collet Chuck Holder ER11 Collet 100 mm Extension Straight Shank Extension rod.
1 Aluminum XL 40 Teeth 12 mm Bore Synchronous Wheel for 11mm Width.
XL-Timing Belt 70XL Rubber Drive Belt Width 10 mm 70 teeth
More all materials take from 3d Printer Machine.
Step 2: DIY Z Aluminium Axis Slide
Material DIY Z Axis Slide:
4 pcs LM12UU 12mm Linear Ball Bearing Linear Bushing CNC parts Linear Bearings LM12
Trapezoidal Rod T8 Lead Screw Thread 8mm Lead 2 mm Length 220 mm with Brass Nut
2 pcs 12mm OD Linear Shaft Length 200 mm Cylinder Liner Rail for 3D Printer Axis CNC Parts
2 pcs C-Beam Linear Rail 4080 clear anodized without cratch Al6063 aluminum Length 160 mm
