Introduction: DIY Squat Rack / Pull-Up Bar
*The pink 2 ft.1 in. rack beams are going to be a variable height depending on how tall you are when you rack the bar. In my case they came out at 2 ft. 1 in. (I am 5' 10")
More references go here.
THE MATERIAL LIST
- 12 count of 1/2 in. x 5 in. Hex Galvanized Lag Screw
- 12 count of 3/8 in. Zinc-Plated Flat Washer (25-Pack)
- 38 count of 1/4 in. x 5 in. Torx Powerlag T-Star Drive Washer Head Yellow Zinc Coated Lag Screw
- 10 count of 4 in. x 4 in. x 8 ft. Untreated Kiln-Dried Douglas Fir Dimensional Lumber
- 2 count 4 ft. x 8 ft. OSB Plywood
- 1 count of 1 in. x 41 in. Black Steel Pipe
- 2 count 1 in. Black Pipe Flange
- 8 count #8 x 1-1/4 in. Phillips Flat Head Zinc Plated Wood Screw
THE TOOL LIST
- Miter Saw
- Impact / Drill Gun (recommend both but you can get away with just an impact)
- #8 Torx Bit
- 1/2" Socket for impact gun (i used a socket wrench for fun but damn my forearms were worked)
- 1" spade bit
- 3/4" spade bit
- 5/16 wood drill bit
11/64 wood drill bit
Right angle tool can definitely help
Hammer or mallet will definitely help
Step 1: Step 1
Use Lag Bolts here.
* Remember to pre drill and drill down to hide the head of lag bolts.
Step 2:
Tighten your flange around the black steel pipe and screw each end in. Use Lag Bolts on the bottom.
Step 3: Step 3
Use Lag Bolts again and drill them at an angle.
Step 4: Step 4
Use lag bolts where the arrows point and use the torx screws for the other parts. I put the torx screws in at an angles for the bottom of the green/pink beams. Then I drill through the top with one screw into the green/pink beams.
* ALWAYS PRE-DRILL HOLES will a smaller drill bit than the width of your screw/bolt.
Step 5:
Use torx screws one on top one on bottom. Rinse and repeat.
The pink rack beams are going to be a variable height depending on how tall you are when you rack the bar. In addition cut the tops of the pink beams at 7-10 degree angle. This will keep the bar from rolling off when racked.
Step 6: Last Step
I drilled the rig down into two osb plywood pieces. This was a game changer for stability.
Step 7: Bonus Addition: Dip Bars
This one is pretty easy add on if you are interested in expanding your rack's capabilities. I would go with a pipe that is 6" longer than the rack for grip to add/remove the bars more easily. As far as pipe diameter it is up to you. .5", .75", 1" all work. I used 1".
