Introduction: DIY Stress Ball
This is a very easy DIY for your own stress ball!!!
Step 1: Step 1: Necessities
You will need:
- Water
- Corn Starch
- Balloon
- Funnel. You can also use the top of a water bottle.
- Spoons
Estimated time: 5 minutes
Step 2: Wrap the Balloon Around the Funnel
Wrap the balloon around the funnel. Make sure that it is very tight so it won't fall off.
Step 3: Add Water
Add some water to your balloon. you don't have to pour a lot.
Step 4: Scoop the Corn Starch
Use the spoon to scoop corn starch into your balloon. You can put quiet a lot in there.
Step 5: Massaging
Massage the balloon with the water and corn starch gently.
Repeat step 3, 4, and 5 a few times until you are happy with the size and the consistency of your balloon.
Step 6: Little Tip!
This is what your balloon and funnel should look like.
Step 7: Use the Spoon to Help You
If the corn starch gets stuck and lumps, get the spoon and slowly push it into the balloon. Make sure you don't make a hole in the balloon.
Step 8: Make a Knot
You are nearly done with your stress ball. The only thing left is to make a knot in the balloon.
Step 9: You Are Finished!
Your stress ball is finished! If you keep the balloon at room temperature it will last pretty long.
