Introduction: DIY Waterproof Flashdrive Casing
This Tutorial is going to show you how you can keep not only your family photos safe, but your flashdrive as well.
Introducing the WATERPROOF FLASHDRIVE CASING. OOOOOOOOOOHHHHHHH...............AAAHHHHHHHHH!!!!!!!! :D
Step 1: Gather Materials
Materials Needed:
-1x latex glove
-1x pair of scissors
-1x roll of electrical tape
-1x flashdrive
-A lot of will power to test if....well you don't have to cause. I already have! :D
-1x latex glove
-1x flashdrive
Step 2: Cut the Fingers
Now I know this sounds gruesome, but it really isn't. Ok, you will need to cut out the thumb, index, middle and ring finger from the latex glove. These will act as the waterproof casing.
Step 3: Applying the Casing
During this step you will need to slide your 1st finger over one end of the flashdrive. Then you will need to slide your 2nd finger over the opposite end. Then slide your 3rd finger over the 1st finger side. Lastly, slide your 4th finger over the 2nd finger side.
Step 4: Applying Tape
Now you will need to wrap the entire casing in electrical tape.
Step 5: Drop in Water.....
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
Step 6: TAKE OUT!!!!
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
Step 7: UNWRAP!!!
Ahhh....your flashdrive is safe....but you still need to test it.
Step 8: TESTING......
Step 9: IT WORKKSS YEAAAHHH!!!!!!
WHOOOOOOOOOOOOOOOOOOOOOO!!!!!!
