Introduction: Daisy Lamp
I wanted a mario bros cross stitched but I don't know how to do cross stitch so hopefully I have a friend who knows and in exchange I made for her a daisy lamp.
That is what I like doing stuff for other people in exchange of other stuff!
So basically, I've done an autonomous purple led lamp in shape of daisy.
Let's see what is inside!
Step 1: Build the Light
I created a simple lighting with blue and red leds to get a purple color but as you can see the blue is dominating.
The effect is pretty cool and the the circuit is really simple.
see attached pictures
Step 2: Design the Daisy Flower :)
I like to draw and here it is my vision of a daisy flower!
I draw on wood and then I cut it.
To be fairly accurate in the cutting process I use a drill to highlight stoke.
then I painted it jwith basic paint and simple colour!
It looks like an innocent flower quite funny.
I let you follow the process. it is quite easy to do!
Step 3: Powered the Light!
I used one ultrafire to powered led and with 1 ultrafire 3.7volts 3000mah I have 72 hours of autonomy!
Which is huge!!!!
For the Ultrafire I build the case using an old el wire case!
Then I set up a switch to turn it on or off :)
Which is huge!!!!
Step 4: Let's Start Your Own Autonomous Light!
You just need to create your own design and add your light behind! The ultrafires are easy to use and last long :)
Enjoy and try ;)
Enjoy and try ;)
