Introduction: Debug Joomla PHP With Eclipse and LAMP on Ubuntu 16.04
The purpose of this Instructable is to setup a LAMP web server on Ubuntu, install a Joomla! Content Management System and finally debug PHP scripts with Eclipse.
A Windows Instructable with XAMPP is located here.
You'll get a quick installation guide in 10 detailed steps. At the end of this Instructable, you're ready to debug your own website. Only freeware software will be used.
Question: Do you need a PHP debugger?
Answer: When you're developing websites in PHP, then the answer is YES.
A debugger can save you a lot of time to find bugs in your PHP scripts, such as Joomla! components, modules or plugins. It allows you to step through the code, set breakpoints, watch variables and many more.
Prerequisites:
- Ubuntu 16.04 clean installation. (32-bit or 64-bit)
- At least 2GB free disk space.
- Internet connection.
Steps:
- Install Apache
- Install MySQL
- Install PHP with phpmyadmin
- Configure Apache Xdebug module
- Install Joomla
- Test Joomla installation
- Install Java
- Download and configure Eclipse
- Create a new PHP project with Eclipse
- Basic Eclipse debugging
Several commands should be executed in a terminal. You can open a terminal with the [CTRL+ALT+T] shortcut. (See screenshot) All commands are executed as a normal user, displayed with a $ prompt. For example:
$ whoami
Note: Copy and paste the commands without the $ character and press [ENTER].
I could not find good tutorials on the web, so I decided to share my experiences with you, step by step. The first step is to setup a LAMP web server which stands for: Linux Apache MySQL PHP.
Let's continue and have fun! :-)
Step 1: Install Apache
Install the web server Apache:
$ sudo apt-get install apache2
You can check the Apache installation by opening a web browser at http://localhost. A welcome message "It works!" will be displayed when the installation is successful.
The root directory of the Apache web server is write protected by default:
$ ls -la /var/www/html total 20 drwxr-xr-x 2 root root 4096 aug 9 20:54 . drwxr-xr-x 3 root root 4096 aug 9 17:26 .. -rw-r--r-- 1 root root 11321 aug 9 17:26 index.html
Add your user to the "www-data" group to add write permission:
$ sudo adduser $USER www-data
Logout and login:
$ gnome-session-quit
Change owner to the group "www-data":
$ sudo chown -R www-data:www-data /var/www
Add group write permission:
$ sudo chmod -R g+rwX /var/www
Now you can create a new file as normal user (without sudo):
$ cd /var/www/html $ touch test.html $ ls test.html test.html
Step 2: Install MySQL
Install the MySQL database server:
$ sudo apt-get install mysql-server
During the installation, you'll be asked to set a root password.
Step 3: Install PHP With Phpmyadmin
phpmyadmin is a web based MySQL administration tool which is a powerful tool for web developers. Frequently used operations such as managing databases, tables, columns, relations, indexes, users, permissions, etc can be performed via a web interface.
Installing phpmyadmin will automatically install and configure PHP.
Note: I could not get phpmyadmin up and running when PHP is already installed.
Install phpmyadmin with the command:
$ sudo apt-get install phpmyadmin
During the installation, you'll be asked to configure the web server automatically. Press [SPACE] to select apache2 and press [ENTER]. (Use [TAB] or arrow keys to navigate).
Answer "Configure database for phpmyadmin with dbconfig-common?" with Yes. ([LEFT ARROW], [ENTER])
Enter the MySQL root password.
Install mcrypt for phpmyadmin:
$ sudo apt-get install mcrypt
Restart Apache:
$ sudo service apache2 restart
Check your installed PHP version with the command:
$ php -v Copyright (c) 1997-2016 The PHP Group Zend Engine v3.0.0, Copyright (c) 1998-2016 Zend Technologies with Zend OPcache v7.0.8-0ubuntu0.16.04.2, Copyright (c) 1999-2016, by Zend Technologies
To check the phpmyadmin installation, open http://localhost/phpmyadmin in your web browser.
Login with user name root and your MySQL phpmyadmin password.
Step 4: Configure Apache Xdebug Module
Xdebug will be used to debug PHP scripts. It should be configured manually in the Apache web server.
Install Xdebug:
$ sudo apt-get install php-xdebug
To find your Apache php.ini configuration file, enter the following command:
$ find /etc/php -name php.ini /etc/php/7.0/cli/php.ini /etc/php/7.0/apache2/php.ini
The Apache PHP configuration file on Ubuntu 16.04 is located in
/etc/php/7.0/apache2/php.ini, but depends on the installed PHP version.
Open php.ini in a text editor, for example:
$ sudo gedit /etc/php/7.0/apache2/php.ini
Add the following lines to the end of the file. Then save the file:
[Xdebug] zend_extension=xdebug.so xdebug.remote_enable=1 xdebug.remote_port=9000
Restart Apache:
Check the Xdebug installation which should display " with Xdebug...":
$ php -v PHP 7.0.8-0ubuntu0.16.04.2 (cli) ( NTS ) Copyright (c) 1997-2016 The PHP Group Zend Engine v3.0.0, Copyright (c) 1998-2016 Zend Technologies with Zend OPcache v7.0.8-0ubuntu0.16.04.2, Copyright (c) 1999-2016, by Zend Technologies with Xdebug v2.4.0, Copyright (c) 2002-2016, by Derick Rethans
Create a new info.php file in the Apache web server root directory:
$ gedit /var/www/html/info.php
Add the following lines and save the file:
<?php phpinfo(); ?>
Note: Please refer to Step 1 Install Apache to fix the permission of the /var/www/html directory when you can't save the file.
Now open a web browser at http://localhost/info.php.
A new xdebug configuration should be displayed. (See screenshot)
Step 5: Install Joomla
Now you're ready to install Joomla.
Download Joomla from https://www.joomla.org/download.html.
In my case, it is saved to ~/Downloads/Joomla_3.6.2-Stable-Full_Package.zip.
Extract the zip file in the /var/www/html directory:
$ cd /var/www/html $ unzip ~/Downloads/Joomla*
Remove the index.html example:
$ rm index.html
Set Apache permission for the Joomla directory:
$ mv htaccess.txt .htaccess
Set user and group "www-data" permission:
Open http://localhost in a web browser to start the Joomla installation.
Set Main Configuration:
- Site Name
- Description
- Administrator Email
- Administrator Username
- Administrator Password
- ConfirmAdministrator Password
Click Next
Set Database Configuration:
- Database Type: MySQLi
- Host Name: localhost
- Username: root
- Password
- Database Name: joomla
- Table Prefix: jos_
- Database Process: Remove
Click Next
Finalization:
Make sure Pre-Installation Check column is green.
Check the /var/www/html permission above when configuration.php Writable is set to No.
Click Install
Congratulations! Joomla! is now installed.
Click Remove installation folder
Step 6: Test Joomla Installation
Open http://localhost in a web browser.
Login with your user name and password.
Open http://localhost/administrator to login in the back-end for administrative purposes.
Step 7: Install Java
Java is required to run Eclipse.
Add the following PPA (Personal Package Archives) to install Oracle Java 8 which includes JDK8 and JRE8:
$ sudo add-apt-repository ppa:webupd8team/java $ sudo apt-get update $ sudo apt-get install oracle-java8-installer
Note: You must agree with the license agreement by selecting: <Yes>.
Check the Java installation, for example:
$ java -version java version "1.8.0_101" Java(TM) SE Runtime Environment (build 1.8.0_101-b13) Java HotSpot(TM) 64-Bit Server VM (build 25.101-b13, mixed mode)
Step 8: Download and Configure Eclipse
Download Eclipse PDT (PHP Development Tools) from:
https://eclipse.org/pdt/#download > Download 32 bit or 64 bit version.
To check if you're using Ubuntu 32 or 64 bit:
$ uname -i x86 < This is 32 bit x86_64 < This is 64 bit
Extract the eclipse-php-neon-R-linux-gtk-x86_64.tar.gz file:
$ cd ~/Downloads $ tar -zxvf eclipse-php*
Start Eclipse:
$ cd eclipse $ ./eclipse
Accept default workspace and click OK.
Close the Welcome tab (by clicking the X).
Click in the toolbar Window > Preferences:
- Click PHP > Interpreter:
This should be set to your PHP version.
- Click PHP > PHP Executables > Add:
- PHP executable tab:
- Name: PHP
- Executable path: /usr/bin/php
- PHP ini file (optional): /etc/php/7.0/apache2/php.ini
- SAPI type: CLI
- Click Next:
- Debugger: XDebug
- Port: 9000
Click Finish > OK.
Step 9: Create a New PHP Project With Eclipse
Now we're ready to create and configure a new PHP project and use existing Joomla sources.
Click in the toolbar: File > New > PHP project:
- Project name: joomla
- Check: Create project at existing location (from existing source)
- Directory: /var/www/html
Click Finish.
Click in the toolbar Window > Preferences > Servers >
Select Default PHP Web Server > Click Edit:
- Click Server tab:
- Server Name: Default PHP Web Server
- Base URL: http://localhost
- Document Root: /var/www/html
- Click Debugger tab:
- Debugger: XDebug
- Port: 9000
- Click PathMapping tab > Add:
- Path on Server: http://localhost
- Path in File System: /var/www/html
Click OK > Finish > OK.
Let's continue to debug your fist Joomla PHP project!
Step 10: Basic Eclipse Debugging
Now you're ready to start debugging.
- Expand the joomla project directory.
- Double click index.php to open it in the editor.
- Set a breakpoint on line 12 (left of the line number).
- Click in the toolbar debug button (small down arrow) >
Debug As > PHP Web Application.
Next time you can click the Debug button in the toolbar instead.
Set Launch URL to: http://localhost/index.php > click OK.
You'll be asked to switch to Debug perspective. Answer with Yes. You can switch back to PHP project perspective by clicking the small PHP button in the upper right corner.
Your default web browser such as Firefox will be opened at: http://localhost/index.php. You can change this for example to Chrome in the Preferences dialog box > General > Web Browser.
The web browser displays a blank white page, because the breakpoint in Eclipse should be reached on index.php line 12.
Now you should be able to step through the code with shortcuts:
- [F5] Step into
- [F6] Step over
- [F7] Step return (or out)
- [F8] Resume (or continue)
Now press 3x [F6].
The $startTime variable is displayed in the Variables tab. Hover over the variable to see the contents of the variable.
Press [F8] to resume. The entire website is now displayed in your web browser.
Refresh your web page in the web browser to reload the page. The breakpoint in index.php line 12 is reached again.
Notes:
- Use the debug button to start a debug session once.
- Use the terminate button [CTRL]+[F2] to stop the debugger.
Step 11: Finally
Congratulations! Now you're completely up and running when you reached this final step.
Feedback is welcome.
Please leave a message when this tutorial was helpful for you.
Thanks!
