Introduction: Desk Notepad
I needed a notepad for my desk, and decided to make one that uses a roll of adding machine paper. This paper comes in rolls that are 2.25 inches wide, and that would suite my needs very well in writing down addresses while on the phone, and making temporary lists.
Supplies used:
- 3/8's inch lumber (I used a small amount of pine from my scrap pile)
- a short length of 3/8's inch dowel
- a short length of brass pin stock (it doesn't have to be brass)
- an old hacksaw blade
- two small screws
- a pair of wooden knobs (purchased from a craft store)
- one roll of adding machine paper
- wood glue
- 4 rubber feet
- wood stain & tung oil
Tools used:
- drill and bits
- band saw
- propane torch (for annealing the hacksaw blade)
- sandpaper
Step 1: Make a Pattern
Begin by drawing a pattern. My pattern is designed for a 7 inch long notepad holder to provide sufficient space for writing. You can make this longer or shorter, depending on your needs. The dimensions of the base plate and ramp are noted as "1" and "2" on the drawing.
Step 2: Cut Out the Wood Parts
Transfer the patterns to the lumber and saw them out. I clamped the left and right sides together and sanded the shape as a unit to make sure they were exactly the same. Also, while they are clamped together drill a 3/8's hole for the spindle that holds the paper roll.
Step 3: Assemble the Parts
Glue the parts together using wood glue. After the glue cured I used small brads to reinforce the glue joints. The brads were probably not necessary, but I like for things to stay assembled!
Step 4: Prepare the Paper Bale and Tear Strip
The paper bale will keep the paper aligned as it comes off the roll and the tear strip will be at the end to allow the paper to be torn off cleanly.
I made the paper bale from a piece of 3/32's brass pin stock, with the ends bent as shown. The tear strip is from a worn hacksaw blade. I heated the blade with a propane torch until it was red hot, then let it cool on its on. This anneals the steel so it can be sawed and drilled. After it was cool, I sawed it to length and drilled holes in each end so it could be mounted (shown in a later step). I also painted the hacksaw blade.
Step 5: Stain & Add Finish
Trim the 3/8's dowel to fit the holder allowing for roughly 3/8's inch overhang. On one side of the dowel glue a knob on, but leave the other side as a friction fit (so the dowel can be removed for paper changes.
Stain the wood (including the knobs) and use your choice of finish. I used tung oil.
Step 6: Install the Paper Bale and Tear Strip
Drill holes at the top of the ramp and mount the paper bale. You will want to leave enough room for the paper under the bale as shown.
At the bottom of the ramp mount the tear strip. I used two thin washers between the tear strip and the ramp to allow room for the paper.
Step 7: Install Rubber Feet
I installed 4 small rubber feet underneath to protect the top of my desk. This also keeps the notepad from sliding around when you write on it.
Step 8: Mount the Roll of Paper
Mount the roll of paper and you're done!
