Introduction: Disappearing Ball Trick
In this trick, the magician places a ball inside a box, covers it up with a handkerchief, lifts the handkerchief up, and the ball disappears.
Step 1: Items
Items you'll need-------
Clear box
a marble
a handkerchief
HAMTARO!!!!!!!!
Clear box
a marble
a handkerchief
HAMTARO!!!!!!!!
Step 2: The Start
Hold out the items and say:
I will place the marble/ball inside the box, cover it, and make it disappear! But first, to ensure that the box is actually solid, I would like someone to examine it
or something like that.
NOTE:::::::::::::::
BE SURE TO LET THEM EXAMINE IT IN THIS PARTICULAR ORDER!!!!!!!!!
Box,
Ball,
then lid.
THE TRICK!!!!!!!!!!!!!
When they have examined the ball and box and they have their attention turned towards the lid, flip the box upside down so the ball is resting on your hands. After they examined the lid, quickley place it on the box.
NOTE:::::::::::::::
Box,
Ball,
then lid.
Step 3: Looks
This is what it should look like.
NOTE::::::
Place the ball between your fingers. Like in the picture.
NOTE::::::
Step 4: The End
When you have the box and ball in place, lay the handkerchief over your hand. Make most of it hang down in the front so the audience can't see the trick.
If your using your right hand to hold the ball, put your left hand under your right hand while holding the handkerchief.
If your using your left hand to hold the ball, put your right hand under your left hand while holding the handkerchief.
Once covered, open your fingers, and drop the ball into your hands. The quicker, the better. Pull away the handkerchief along with the marble and put it in your pocket. The ball has "mysteriously" disappeared!!!
