Introduction: Disposable Faceplates - for the Lathe
All wood lathes come with a face-plate to get you turning right away. I use mine quite a bit for large projects, but oftentimes the face-plate is too large for a project. Or there is not a lot of extra wood available for screws to bite into without ruining the project. And sometimes, I have a project in finishing stage still attached to the faceplate. Even with a decent chuck for my lathe, I still find these to be very handy to have on hand.
I don’t have a second faceplate right now, nor do I need one often enough to justify buying another. So I got one of those metal taps that fit the thread size/pitch of my lathe spindle. Most specialty woodworkers supply stores carry the common sizes for your lathe, and most are flat bottoming taps. I will say that they are a bit overpriced for my taste (I’m cheap) and there are cheaper ways to get this done. I don’t think you need a flat bottoming tap, as the hole goes through the full thickness of the block of wood.
You can buy individual taps from tool supply companies. You do not have to buy a full set of. Ask your auto parts store clerk if they carry them. They do not have to be expensive name brand taps, they can be cheap ones. You are only cutting wood and these are made to cut metal..
Step 1: Gather Material and Scrap-wood
In this instructable, I am using scrap 2X4 material. Start by cutting square blocks. I used a miter saw for this along with a stop block for repetitive accuracy.
I usually make a few at a time so I have many on hand.
Step 2: Mark Centers and Drill the Holes
It is important you know your proper spindle size before drilling the hole. My lathe spindle is 1"-8TPI. I need the same sized tap.
The spindle is 1", I use a 7/8" bit for the hole. If your tap is a bottoming tap you will be able to use thinner stock for your faceplate, But I wouldn't use anything under 1" thick material for these face plates. I drill all the way through the block. and have a scrap wood block under the face-plate block to prevent tear-out.
Once you have all the holes drilled, it's time to tap them.
Step 3: Time to Tap
Moving on...
Step 4: How to Use Them
2X4 material is 1-1/2" thick. This thick of material will seat on the spindle without a washer behind it, but there are cases where I will put a washer behind the block so that I can use thinner material for a face-plate.
Once you have the face-plate tight on the spindle and seated nice and solid, set-up your tool-rest and round the block of wood.
Then re-adjust the face-plate to the face and flatten and square the bottom.
Now your face-plate is ready to be glued to a project. I keep it on the lathe and use the tail-stock as a clamp. you may have to get creative.
These really are handy in a pinch and are cheap and easy to make.
Thanks for looking.
