Introduction: Dot Matrix 32x8 Max7219 Interfacing With Ardiuno
Hi All,
Dot Matrix based o Max7219 are not new in 2020, until recently, the setup process was well documented, one would download hardware library from MajicDesigns. and changed few lines in the header files and FC16 worked like a charm. This was till MajicDesigns fixed all bugs in the library. Now the documented method doesnot work..
I spent few days searching and discovered it by chance..It may be some experts may know it already. But thought to document and share it, to help other newbies like me
Step 1: What Do We Need?
  • Max7219 32 x 8 dotmatrix board
  • Ardiuno Nano
  • Bread board
  • Some wires
  • Laptop or Desktop with Ardiuno ide
Step 2: Max7219?
  • If you are unsure if you have max7219, not pop out the led dot matrix
  • Use your mobile phone to zoom and take a pic
  • This makes it easier to read
Step 3: Install Driver
  • in Ardiuno Ide, go to "Tools" > "Manage Libraries"
  • Then search for md_max
  • Install "MD_MAX72xx" and "MD_Parola"
  • Restart Ardiuno just to make sure libraries are loaded
Step 4: Error and Solution
  • Make connections as per the code
    • CLK_PIN 13
    • DATA_PIN 11
    • CS_PIN 12
    • Adjust Max_device to 4
  • I tested it with different examples but i noticed that the characters were jumbled
  • Sometimes it may be because of loose connection/wire on breadboard
  • In most of the case it is due to incorrect HW initialized
  • There are 4 hw based on connections
    • MD_MAX72XX::PAROLA_HW
    • MD_MAX72XX::GENERIC_HW
    • MD_MAX72XX::ICSTATION_HW
    • MD_MAX72XX::FC16_HW
  • "Parola_HW" is default, we need to test one by one to check which works best
  • Remember to reset power for Ardiuno before you test each setting
  • For me FC16_HW worked
Step 5: Adjust the Code
  • Update hardware type to "FC16_HW"
  • Max_device as 4 for 32 x 8 matrix
  • Write the code back into the Ardiuno Nano
  • Test the display
  • Voila it works !!
Hope this helps someone in future.
Please share your comments and suggestions
