Introduction: Double Barrel Knex Pistol
I made this so i had a chance to fire two shots at once, its not the most powerfull thing in the world but its pretty good. Oh and THIS IS MY FIRST INSTRUCTABLE.
Step 1: Build the Firing Pin
Ok for this you will need
2 red rods
2 blue rods
2 white/yellow conectors
4 grey spacers(these each substute 3 blue spacers)
and one black/brown/orange conector(looks like a tall H)
2 red rods
2 blue rods
Step 2: Make Upper Barrel Suport
For this part you will need
Red Rod
Grey Cap Conector
2 Red Conectors
Red Rod
Grey Cap Conector
2 Red Conectors
Step 3: Make Central Barrel
On a new Red/Green rod you will need
2 Hubcap conectors
5 Red/Grey conectors
NOTICE: The last Hubcap Conector is sideways.
2 Hubcap conectors
Step 4: Make Lower Barrel and Trigger
NOTE: THIS PIECE GOES ON THE OPPASITE WAY SO THE OTHER END (TURN IT ARROUND)
This step is confusing you need:
A green rod
A White/black for (for the trigger
2 White (not snowflake) connectors
2 Snowflake connectors
3 Brown/orgage (H peice) connectors
1 Light grey connector (2 prong)
6 Red Connectors
1 Hubcap
A green rod
6 Red Connectors
1 Hubcap
Step 5: Add Parts Together
Ok This is the hardest part of the gun
Add parts 2,3,4 all thogether ok so we will do it a step at a time
PARTS 2 AND 4=
Look at pic one
PARTS 2,3,4=
Look at pic 2
NOTE DOO EVERYTHING IN THE SAME ORDER IF NO SPACE MAKE SPACE MOVE A FEW THINGS.
PARTS 2 AND 4=
Look at pic one
PARTS 2,3,4=
Look at pic 2
Step 6: Make Handle
This is really easy...
You need 2 Blue rods
4 anything i recomend hubcaps (at the top of handle i didnt have enough peices)
1 yellow/white conector
4 Orange/brown conectors(H peice)
And one metalic blue conector.
Step 7: Adding Handel to Barrels
THIS IS EASY
NOTE THE SIDEWAYS HUBCAP THATS WAT GOES BETWEEN THE H PEICES
Step 2
you need 2 more H peices
Put an h piece behind the last H pice of the handle and conect it between the 2 snowflakes
Put the other one infront of the sideways hubcap and conect it behind the trigger.
Step 2
Step 8: Adding Rubber Bands
Add rubebr bands from the firing pin to the front of the gun (in the pic)
and from the trigger to handle.
AND YOUR DONE!!!
PLEASE COMMENT AND TELL ME HOW MY FIRST INSTRUTABLE WAS.
AND YOUR DONE!!!
