Introduction: Dr Strange Movie Cosplay With Props
About: hello
Well...... I had to make a Duo Day Costume for my school so i decided to use Dr. Strange and Mordo. I based off my costume on the new movie so i thought it was pretty good so i hope you'll enjoy.
So for the costume you will need:
- Dark blue dress shirt ( long sleeve)
- Dark Blue pants ( long )
- 86 in. dark blue curtain
- Black combat boots
- Brown cloth belt
- Red cape (with pop up collar)
- Black and white face paint
- Wooden hangar clips
- Cardboard( lots )
- Metallic gold spray paint
- Eye of Agamotto Template
Step 1: Eye of Agamotto
first you have to print the eye of agamotto template twice to make it look 3D.
The you have to glue all the pieces to the cardboard to cut them out
You will only use the ones circled in the template
after they are glued to to the cardboard, you will cut them out with the x-acto knife
after this you will cut one of the large pieces as the weird hastag thing in the middle
then you will cut the rest into rings on the inside
then you put the eye lid into the center
then you glue all of the pieces together
use the video as reference
PS
if you want to you can spray paint the Eye a little to make it look metallic
Step 2: Sling Ring
For the sling ring i used a lot of pictures off the internet as reference so you can change the look as you think best
First i took one of the wooden clips and tore it apart into the three parts it has:
The two wooden parts and the metal part
Discard the metal part ( its useless )
Then you cut the wooden parts at the length of the two fingers you are going to use it on
Next you glue them together
after this you use cardboard to make the actual ring part. You wrap the cardboard around the two fingers used and you glue them together onto the wooden parts
Then you spray paint the parts to make them look shiny and metallic
Step 3: Shirt and Tunic
I used a Dickies long sleeve work shirt and curtains for that part.
I put on my shirt, cut the curtains in half, and used one of them on each side of my body
I used safety pins so that the curtains would not slip
Then you tie the curtains together at your waist with your belt
The cape was kind of last minute and i just inverted a black vampire cape to the red side out and put it over everything and it looked good
but if you prefer an all red cape you can use red fabric paint to paint the cape
Step 4: Pants and Boots
i just found some of my dad's combat wear laying around and i used it but if you cant find this stuff you can use black jeans and black booted shoes
i dont think people will mind too much how this looks like
plus it will be hidden by the "tunic"
Step 5: Make Up
I based the make up on pictures of Dr. Strange so its legit
I used the white Face paint of the white hair and the black for the beard
I also used gel for my hair
Step 6: End
I hope you enjoyed this tutorial and i hope to be making more so give me feed back for the next cosplay
