Introduction: Dragon Viking Shield
My son wanted to be a Viking for Halloween. So, with a few sheets of cardboard, a bowl and some duct tape I built him a Viking shield even Gobber would be proud of. Remember,
“Your most important piece of equipment is your shield. If you must make a choice between a sword or a shield, take the shield!"
- Gobber
Step 1: Materials
Materials for the shield,
- Two large pieces of cardboard
- Small metal bowl
- Three rolls of duct tape
- one roll of red
- one roll of silver
- one roll of brown
- One roll of mat-tact (sticky vinyl wood sheets your grandma placed in her cupboards)
- An exacto knife
- Black marker
Step 2: Front and Back Pieces
On one sheet of cardboard, draw straight lines from opposite corners making an X in the middle. Tape the two pieces of cardboard together then place a thumbtack in the centre of the X and press hard enough to pierce both sheets. Pull off a strip of duct tape longer than you need, in my case 11 inches, and place the thumbtack in the middle near one end. The thumbtack should go on the sticky side and placed back into the centre of the cardboard with the colored side down. Make a hole in the other side of the tape the radius of the circle, place a pen in the hole and trace around. Cut the two cardboard sheets into 18 inch diameter circles. You can make it larger or smaller to suit.
If your circle is too small, no problem. Just cut out a bigger hole. Too big and your starting over. It’s best to trace out a couple holes before cutting them out.
Step 3: Adding the Wood
Take your back piece and place it on the mat-tact to adjust the fit. Peel the backing off and place the cardboard onto it. Push out all the air bubbles and make two small cuts to either side of the inner circle. This is where you will be adding the straps.
Step 4: Give It Some Girth
Now to give your shield some depth. You want to make a ring around the circumference of the shield and another ring around the bowl. Cut out 5-6 strips from your remaining cardboard as wide as the gap between your front and back pieces. Make sure to cut across the corrugated parts, this will provide a more ridged support. Roll the strips up and tape them to the side of your shield.
Step 5: Braces
Cut out three strips of duct tape about 14 inches long. Slice the strips down the middle then fold one third to the centre and the other third on top. When you have six folded strips, braid them together to form the two handles. Push the ends of the braids through the two slits made in the back piece and adjust the fit. Tape the ends to the inside of the shield.
Step 6: Steel Banding
Using your bowl as a tracing tool again, cut and stack four pieces of the shiny duct tape. Place the bowl over it so that bowl doesn't quite touch the top. Trace around the bowl and cut out the shapes. These will be used later.
Step 7: The Umbo or Shield Boss
Step 8: Give It a Coat of Red
Step 9: Putting It Together
Sandwich the bowl between the front and back pieces. Use you silver duct tape and tape the front and back together. Leave enough of the tape overlapping the sides to match the overlap in the centre. One piece did not cover enough, so I wrapped the shield again, leaving the same over lap on the back piece.
Decorate the shield with Viking runes, scuff marks or just bring it into the dragon training academy.
"Remember today is about survival. If you get blasted......you're dead! What's the first thing you'll need?" - Gobber
