Introduction: Dust Proof Room for Garage & Workshop
Wood is an amazing material but its main disadvantage is the massive mess it makes. Therefore, today's project is going to be a dustproof area that will contain the dust and prevent it from spreading throughout the workshop.
What you will need:
- Wooden Planks
- Plastic Sheets
- Strong Tape
- Screws
- Wall Inser
Step 1: Step 1: Cut & Mark the Wooden Pieces to Length
Using the wall as a reference mark your wooden pieces, then cut them to length using a circular saw.
Once done, mark your holes around 20 cm apart.
Tip: You can also draw an arrow to memorize the direction of your wooden pieces.
Step 2: Step 2: Drill the Planks and the Wall
Using a 3mm bit, pre-drill your wooden pieces.
Then using the same bit mark your holes on the wall, by placing the wooden plank in place and drilling 1 mm deep in the wall.
Then using a larger drill bit, drill your walls. (Tip: Use a vacuum drilling attachment to prevent making a mess)
Finally hammer your wall inserts in place and screw the wooden pieces to the wall.
Step 3: Step 3: Install the Plastic Sheets
Using very strong tape, tape the plastic sheets together. (I used cloth tape)
After that use a stapler to staple the plastic sheets to the wooden pieces.
Step 4: Step 4: Most Important Step!
Make sure to check out my youtube channel for more interesting projects.
You can also support me by Liking and Subscribing to my Channel!
