EASY Extendable Pole Mount for ANY Camera
Intro: EASY Extendable Pole Mount for ANY Camera
Hi everyone!
In this ible I'll show you how to make an easy and very cheap Pole Mount for any kind of Camera. I decided to use an extendable pole whose length can be set from 75cm to 150cm.
Two weeks ago I realized this mount (photo#2) to put on the seatpost in order to film from a cool point of view.
Since the extendable pole that we are going to use in this ible it's obviously a tube too (like the seatpost tube), I used that mount. I removed it from the seatpost and I secured it on the pole changing the two original screws with two small bolts and nuts in order to make it sturdier.
NOTE: If you have never watched my "EASY Bike Seatpost Mount" ible, please click here to understand better the few steps needed to built this mount.
STEP 1: Materials and Tools
MATERIALS:
- extendable pole (1$)
- 1/4" screw (I took and cut this one)
- universal 1/4" Mini Tripod Mount Adapter (If you don't own a GoPro and you are going to use a normal camera, you need this adapter)
- cheap bicycle bell (1$)
- little piece of bicycle tire
- two nuts and two bolts
TOOLS:
- screwdriver
STEP 2: The Mount
As I said you in the intro, you can click here to understand better the building of this mount.
It's way way easier than you think! ;)
I simply dismounted the bike bell keeping only the flat base (photo#4), I drilled a hole in the center and then I inserted the cut 1/4'' screw, his couple of nuts, a rubber gasket (taken from a beer) to fill the gap, and finally the tripod mount adapter and the universal 1/4" mini tripod mount adapter.
GoPro tip: If you have a GoPro don't worry! You just need to assemble it in the same way, mounting your GoPro case directly to the tripod mount adapter without the universal 1/4" screw.
STEP 3: Secure It on Your Pole
After the building, you will just have to secure it on the pole.
I decided to change the two original screws with two small bolts and nuts to make it more sturdy and, in order to prevent the slipping of the mount from the pole, I also added a small piece of bicycle tire on its end before attach the mount.
Once you've screwed all as tight as possible, you can mount on your camera.
STEP 4: Finish!! Go Out and Have Fun
As promised, in about 10 minutes you can build your cheap, extendable and universal pole mount.
Since this is an universal mount it's a very useful project. Infact you can screw on any kind of camera! A compact camera, an action one, and even a GoPro.
As you can see in photos I prefer to set the pole about 100cm long.
Thank you for reading my Instructable. ;)
Feel free to comment and ask if you need to know something!
manuelmasc
31 Comments
C NickO 9 years ago
can't find extendable pole for under $20. not in market, hardware store and also online.
manuelmasc 9 years ago
where do u live? here in italy they are very common and not that expensive...
C NickO 9 years ago
LiamA6 9 years ago
fixfireleo 10 years ago
awesome!! you should film yourself all day everyday and make a movie!! you could be the next brad pitt!
manuelmasc 10 years ago
oh really?? ahahha
audreyobscura 10 years ago
So simple! Thanks for the share!
;) thanks
nerfrocketeer 10 years ago
you are welcome ;)
dmoonen 10 years ago
This is a great way and can be soooooo cheap...
thanks very much ;)
sue.centeno 10 years ago
awesome.....thanks for sharing :)
thanks! you are welcome
p_brums 10 years ago
they sell it in market, hardware store and also online. they are very cheap
tgonzález-crespo 10 years ago
In any hardware store that sells paint.
alcurb 10 years ago
Added your project to my FotoTrix collection
What was the source of your extendable pole? What is the pole normally used for?
thanks! it comes from a sweep. (it's normally used to clean the floor from the dust)
