Introduction: EASY Washing Machine Toy- DIY Project
Hi guys, welcome to my new project : washing machine. In this article, I will show you how I made it and hope you will make one for yourself.
If you want a more visual instruction please click to this below instructional video.
If you like, SUBSCRIBE my youtube channel ☞☞☞ HERE ☜☜☜. I always update my new projects everyweek.
Lastly, if my little washing machine is interesting to you, please VOTE for me in Cardboard contest.
I am very appreciated your support.
Now, let’s do it.
Here are thing that you will need
2 X Soft drink cans
1 x 3-5 V DC MOTOR
1 X battery1
x switch
Hot glue
Paper knife
Step 1:
Draw 4 rectangular with 9x13 cm in size and 4 9x9cm squares.
Then cut them off.
Step 2:
Use bottom of a can to draw a circle on 1 rectangular.
Draw a small rectangular, fit with switches size.
Then cut them off for.
Step 3:
Cut a can bottom.
To make it easy, you can see the technique I use in the video at minute 1:22
After that, stick a transparent plastic circle to the cut bottom.
Cut out 1cm straw to make the hinge.
Stick the hinge to the rectangular.
Now, we have the front door of our machine
Step 4:
Cut a can in half.
Flip the rectangular to it backside, draw a circle with equal size with the can’s mouth
Cut a ring from the can.
Cut it in half then stick the pieces to the drawn circle.
Step 5:
Make a hole in the middle of can bottom.
Stick the motor to the can through that hole.
Step 6:
Stick a 9x9 cm rectangular to the front cardboard.
Soldering motor to switch battery
Glue the motor to another 9x13 rectangular and stick that rectangular to the bottom cardboard.
Stick battery
Step 7:
Glue the other side boat to the model.
Now, our model is ready to work.
Upgrade tip
MAKE SOME HOLE ON THE SPIN TUB, YOUR WASHING MACHINE WILL WORK AS REAL ONES.
Thank you for reading my instruction
See you in the next project.
Subscribe my youtube channel for more.
