ESP32: How to Interface LCD With ESP32 Microcontroller Development Board
Intro: ESP32: How to Interface LCD With ESP32 Microcontroller Development Board
Hello World!
In this Instructables we will be learning how to interface a 16x2 LCD with the ESP32 Microcontroller Board. There are currently no tutorials online on how to interface it, so I decided to share with you my experience and knowledge on how to connect this together!
The LCD display is one of the most versatile electronic component in the maker market so it is wise to learn how to interface it so as to apply his knowledge to many other applications that you will discover as a maker.
Let's get started!
STEP 1: BoM
* ESP32 Microcontroller Development Board
* 16x2 LCD
* A Lot of Jumper Wires
* Potentiometer
STEP 2: Connections
Follow the table below for a concise and comprehensive guide on how to connect all the pins of the LCD screen to both the potentiometer and the ESP32 micro controller development board
LCD PinPotentiometer Pin ESP32 Pin 1 and 16 1 GND2 and 1533.3V32 - Signal pin 4225GND6237unused8unused9unused10unused115121813191421
STEP 3: Code
#include <LiquidCrystal.h>
LiquidCrystal lcd(22,23,5,18,19,21);
void setup() { lcd.begin(16, 2); lcd.clear(); lcd.print("How to Interface"); // go to row 1 column 0, note that this is indexed at 0 lcd.setCursor(0,1); lcd.print ("LCD with ESP32"); }
void loop(){}
STEP 4: Contrast Control
Turn the knob of the potentiometer to change the contrast of the LCD. When you first upload the program onto the ESP32 board you may find that you're not seeing anything on the display, this is likely because the contrast is not set properly.
Turn the knob until you can see the display clearly.
14 Comments
marco4zoom 3 years ago
Main components:
ESP32-WROOM-32D
1602A LCD Display
Potentiometer (best = 10k to 20k)
200-220 Ohm Resistor
ESP32 Pins used
Power
5V
GND
Data
ESP32 GPIO15
ESP32 GPIO16
ESP32 GPIO17
ESP32 GPIO18
MISO - ESP32 GPIO19
MOSI - ESP32 GPIO23
LCD Pin Connections
PIN01 -> GND
PIN02 -> 5V
PIN03 -> Signal pin of Potentiometer (usually the middle pin)
PIN04 -> ESP32 GPIO19
PIN05 -> GND
PIN06 -> ESP32 GPIO23
PIN07 -> NOT USED
PIN08 -> NOT USED
PIN09 -> NOT USED
PIN10 -> NOT USED
PIN11 -> ESP32 GPIO18
PIN12 -> ESP32 GPIO17
PIN13 -> ESP32 GPIO16
PIN14 -> ESP32 GPIO15
PIN15 -> Use 200 Ohm Resistor to 5V
PIN16 -> GND
Potentiometer
PIN01 -> 5V
PIN02 -> LCD PIN03
PIN03 -> GND
REMEMBER IN THE ABOVE SITUATION THE RIGHT LIBRARY SETUP IN ARDUINO IS:
const int rs = 19, en = 23, d4 = 18, d5 = 17, d6 = 16, d7 = 15;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
THE ABOVE SITUATION IS GOOD WITHOUT ANY LEVEL ADAPTER (5,0 to 3,3 volts) BECAUSE IS WRITE-ONLY ( from ESP32 to LCD 1602A)
robmurg 4 years ago
Adoher 4 years ago
bloodyrackham 4 years ago
Main components:
ESP32 Pins used
Power
Data
LCD Pin Connections
Potentiometer
TechMartian 4 years ago
Too_old_for_this 4 years ago
nj1377 5 years ago
temper 5 years ago
If any one works it out please let us all in on the "trick".
MiguelT40 5 years ago
ShashiK3 5 years ago
I have a ESP32 DevKit 1 and I connected to LCD 1602A,
I even connected to 5V to pin 2 GND to Pin 1 of the LCD screen, and the Potentiometer connected to 5v, GND and the middle to Pin 3 of LCD.
The connections RS, EN and pin 11,12,13 and 14 were connected to. Still not working.
ManosZ1 7 years ago
laurentR15 7 years ago
Hello,
Do you use a LCD1604 5v ? I don"t see any comment about the issue 5v/3.3v. ESP32 works with 3.3v but common LCD1604 works with 5v. How do you manage that ??
Laurent.
I mean LCD 1602A
