Introduction: ESP8266 Wifi Temperature Logger
They day I read at hackaday (http://hackaday.com/tag/esp8266/) that a new $5 wifi module was available, I order a few of them to test. Now, a few weeks later I want to share my experience.
This is a very simple demo using the ESP8266 and Arduino to update a remote server (https://thingspeak.com/) using a digital temperature sensor.
These are really exciting times for the Internet of Things (r)evolution. Prices are coming down and the Maker community is eager to develop the next generation of all things connected.
The following setup could be done under $20. This is using off the shelf "pricey" components (like Arduino), but you could program your own MCU with UART support and make it cheaper.
Step 1: Materials
Step 2: ESP8266 Setup
This is where things got tricky. I spent a lot of time testing different configurations. Note that are two version of the ESP8266 going around. The first one has the notification LEDs right next to the board pins. The second one (newer) has the LEDs by the antenna. I have the second one.
The best results came when I loaded V0.922 which allowed me to change the baud rate to 9600. Follow these steps to load this firmware.
http://www.electrodragon.com/w/Wi07c#Firmware_uploading_tool
The best way to test a good connection is by using a USB-to-TTL cable and using a terminal like CoolTerm. Here is the command to change the baud rate:
  • AT+CIOBAUD=9600
These are the pin connections I used on ESP8266 to USB-to-TTL. I used the regulated 3.3v vcc of the Arduino to power the ESP8266. I know that Arduino vcc 3.3v max is output is 150 mA and ESP8266 will peak at 240 mA. But at the time I had no other regulated 3.3v available. Regular usage for the ESP8266 is at 70mA.
Remember to connect GPIO0 to GND when you are uploading new firmware. After that remove for normal operation.
UTXD --> RX (USB-to-TTL)
CH_PD <--> VCC
RST
VCC --> VCC (power source)
GND --> GND (power source)
GPIO2
GPIO0
URXD --> TX (USB-to-TTL)
*Note also had to do USB-to-TTL GND to Arduino GND
Step 3: Arduino Setup and Sketch
ESP8266 to Arduino
UTXD --> RX Arduino
CH_PD <--> VCC
RST
VCC --> VCC Arduino
GND --> GND Arduino
GPIO2
GPIO0
URXD --> TX Arduino
Digital Temperature Sensor to Arduino
Arduino GND -- > DS18B20 GND(1) -- > DS18B20 VDD(3)
DS18B20 DQ(2) -- > 4.7K R --> VCC Arduino 3.3v
#include<stdlib.h>
#include <SoftwareSerial.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 8
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);</p><p>
#define SSID "[YOUR_SSID]"
#define PASS "[YOUR_PASSWORD]"
#define IP "184.106.153.149" // thingspeak.com
String GET = "GET /update?key=[THINGSPEAK_KEY]&field1=";
SoftwareSerial monitor(10, 11); // RX, TX
void setup()
  monitor.begin(9600);
  Serial.begin(9600);
  sensors.begin();
  sendDebug("AT");
  delay(5000);
  if(Serial.find("OK")){
    monitor.println("RECEIVED: OK");
    connectWiFi();
void loop(){
  sensors.requestTemperatures();
  float tempC = sensors.getTempCByIndex(0);
  tempC = DallasTemperature::toFahrenheit(tempC);
  char buffer[10];
  String tempF = dtostrf(tempC, 4, 1, buffer);
  updateTemp(tempF);
  delay(60000);
void updateTemp(String tenmpF){
  String cmd = "AT+CIPSTART=\"TCP\",\"";
  cmd += IP;
  cmd += "\",80";
  sendDebug(cmd);
  delay(2000);
  if(Serial.find("Error")){
    monitor.print("RECEIVED: Error");
    return;
  cmd = GET;
  cmd += tenmpF;
  cmd += "\r\n";
  Serial.print("AT+CIPSEND=");
  Serial.println(cmd.length());
  if(Serial.find(">")){
    monitor.print(">");
    monitor.print(cmd);
    Serial.print(cmd);
  }else{
    sendDebug("AT+CIPCLOSE");
  }else{
    monitor.println("RECEIVED: Error");
void sendDebug(String cmd){
  monitor.print("SEND: ");
  monitor.println(cmd);
  Serial.println(cmd);
boolean connectWiFi(){
  Serial.println("AT+CWMODE=1");
  delay(2000);
  String cmd="AT+CWJAP=\"";
  cmd+=SSID;
  cmd+="\",\"";
  cmd+=PASS;
  cmd+="\"";
  sendDebug(cmd);
  delay(5000);
    return true;
  }else{
    return false;
*UPDATE. Once your done testing/monitoring. Load the same sketch without SoftwareSerial Monitor. This gave me better results as stand alone.
#include
#include
#include
void setup()
  Serial.begin(9600);
  sensors.begin();
  Serial.println("AT");
  delay(5000);
    connectWiFi();
void loop(){
  char buffer[10];
  updateTemp(tempF);
  delay(60000);
  cmd += IP;
  cmd += "\",80";
  delay(2000);
    return;
  cmd = GET;
  cmd += tenmpF;
  cmd += "\r\n";
    Serial.print(cmd);
  }else{
    Serial.println("AT+CIPCLOSE");
  delay(2000);
  cmd+=SSID;
  cmd+="\",\"";
  cmd+=PASS;
  cmd+="\"";
  delay(5000);
    return true;
  }else{
    return false;
Step 4: ThingSpeak Setup
ThinkSpeak is just awesome! Follow these simple steps to start you own feed:
  1. Sign up for a FREE account at https://thingspeak.com/
  2. Go to Channels --> Create New Channel (you can leave all defaults)
  3. Go to API Keys and get your KEY
  4. Test by putting this on your browser
    http://api.thingspeak.com/update?key=[THINGSPEAK_KEY]&field1=0
  5. Check your results
    http://api.thingspeak.com/channels/[CHANNEL_ID]/feed.json?key=[THINGSPEAK_KEY]
Now you are ready to start sending data.
