Introduction: Easter Egg Painting
This lesson will teach you how to paint an egg, for Easter. It's almost a month away might as well be prepared. They're many ways to paint eggs. A plethora of colors to choose from bright to brighter to make the main color. The fast and easy way, just go through the steps and see for yourself.
The materials you will need
-Food Coloring dye
-Egg (boiled)
-Cup of water
-Any paint marker(s)
-Spoon with holes
Step 1: Dying the Egg
You will need your boiled egg, a cup, water, dye, and something to scoop out the egg once you're done. The first thing you should do is get the water (poured into the cup) and put 4 to 5 drops of dye, mix it all together. Take the egg very gently put it into the dyed water for 3-5 minutes. Take it out and then you should have a lightly colored egg.
Step 2: Painting Your Egg
Once the egg had dried from being dipped in the water, you make use of striped lines, zigzag lines, and even wavy lines. You will first need your colorful marker to use, shake it really well before using though. You could add circles, stars, and if you want even tiny egg drawings. You should use 1-3 light-colored markers(I would recommend posca paint markers)
Step 3: The Final Result
The egg should look iconic and bright.
