Introduction: Easy DIY Crystal Earrings and Pendant
Step 1:
For this project you will need:
For the Pendant~ 1 focal, top-drilled briolette bead or crystal, 2 inches wire to fit through your bead and 1 finished chain
For the Earrings~ 2 focal, top drilled briolette beads or crystals, 2-3 inches wire to fit through beads, 2 ear wires
Tools: Wire Cutters and Round Nose Pliers
Step 2:
Cut wire to desired length, usually between 1-2 inches. Use your round nose pliers to form a small loop at one end of your wire.
Step 3:
Use your round nose pliers to form a similar loop on the other side of the wire, then center your bead.
Step 4:
Push even lengths of the wire up along each side of the bead so the loops are pressed together.
Step 5:
Add a chain for a pendant or a jump ring and ear wires for earrings.
Step 6:
Enjoy!
