Introduction: Easy and Simple Filet Crochet Table Runner
Crochet Filet is a very easy crochet technique which uses Chain Stitches and Double Crochets. Filet Crochet works up really quick. Filet is a very delicate technique that creates beautiful patterns. With just two simple stitches you can create lovely patterns.
Crochet Filet technique in itself is a very versatile. You can make many decorative crochet projects with this technique. Today am sharing the pattern for a Easy and Simple Filet Crochet Table Runner.
Table runners are very easy to crochet. You can make them in any size of your need. They are a great way to decorate your Coffee table or Dining Table. They are also a great option for gifting it to your loved ones.
Base - 10 inches - Customizable to any size
Length - Customizable to any size
Visit https://rajiscrafthobby.blogspot.com/2023/05/easy-and-simple-filet-crochet-table.html
4 Ply Cotton Knitting Yarn
4 mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:-
Start with a Slip Knot.
Chain 39.
This measures around 10 inches.
You can adjust the size by altering these stitches according to your requirement.
Start with any odd number of Chains.
Step 3:
Round 2:-
1 Double Crochet in the Third Chain from the hook.
1 Double Crochet each in the remaining stitches.
Once you reach end, Chain 2.
Straight Edge Turning Chain:-
Usually you would Chain 2, turn and start working the next round. Here is a quick tip to have a nice straight edge .
- Insert the hook into the 1st chain from the bottom.
- Yarn over and pull up a loop. You should have 2 loops on the hook.
- Turn your project and insert the hook into the first stitch.
- Yarn over and pull up a loop. You will have 3 loops on the hook.
- Again, yarn over and pull through 2 loops. You will have 2 loops on the hook.
- Lastly, yarn over and pull through 2 loops.
- This will make one Double Crochet.
Step 4:
Round 3:-
(1 Double Crochet is already made while making the turning chain)
1 Double Crochet each in the next 5 Stitches(that's total 6 Double Crochets made).
Skip 1 Stitch.
Chain 1.
1 Double Crochet each in the next 6 stitches.
Skip 1 Stitch.
Repeat(1DC*6,Sk1Ch1).
1 Double Crochet each in the last 2 stitches.
Once you reach the end ,Chain 2 and use the Straight Edge Turning chain method mentioned in the previous round to make the turning chain.
Step 5:
Round 4:-
1 Double Crochet in the next 2 Stitches(i.e.-make the stitch in the Chain 1 Space too. That's total 3 Double Crochets made).
Skip 1 Stitch.
Chain 1.
Skip 1 Stitch.
1 Double Crochet each in the last 5 stitches.
Once you reach the end ,Chain 2 and use the Straight Edge Turning chain method to make the turning chain.
Step 6:
Round 5:-
1 Double Crochet in the next 3 Stitches(That's total 4 Double Crochets made).
Skip 1 Stitch.
Chain 1.
Skip 1 Stitch.
1 Double Crochet each in the last 4 stitches.
Step 7:
Round 6:-
1 Double Crochet in the next 4 Stitches(That's total 5 Double Crochets made).
Skip 1 Stitch.
Chain 1.
Skip 1 Stitch.
1 Double Crochet each in the last 3 stitches.
Step 8:
Round 7:-
1 Double Crochet in the next Stitch(That's total 2 Double Crochets made).
Skip 1 Stitch.
Chain 1.
Skip 1 Stitch.
Step 9:
Round 8:-
1 Double Crochet each in the next 6 Stitches(That's total 7 Double Crochets made).
Skip 1 Stitch.
Chain 1.
Skip 1 Stitch.
1 Double Crochet in the last stitch.
Step 10:
Round 9:-
Skip 1 Stitch.
Chain 1.
Skip 1 Stitch.
Step 11:
Round 10:-
Skip 1 Stitch.
Chain 1.
Skip 1 Stitch.
Step 12:
Round 11:-
1 Double Crochet each in the next 4 Stitches(That's total 5 Double Crochets made).
Skip 1 Stitch.
Chain 1.
Skip 1 Stitch.
1 Double Crochet in the last 3 stitches.
Step 13:
Round 12:-
1 Double Crochet each in the next 3 Stitches(That's total 4 Double Crochets made).
Skip 1 Stitch.
Chain 1.
Skip 1 Stitch.
1 Double Crochet in the last 4 stitches.
Step 14:
Round 13:-
1 Double Crochet each in the next 2 Stitches(That's total 3 Double Crochets made).
Skip 1 Stitch.
Chain 1.
Skip 1 Stitch.
1 Double Crochet in the last 5 stitches.
Step 15:
Round 14:-
1 Double Crochet each in the next 5 Stitches(That's total 6 Double Crochets made).
Skip 1 Stitch.
Chain 1.
Skip 1 Stitch.
1 Double Crochet in the last 2 stitches.
Step 16:
Round 15:-
1 Double Crochet each in the next 7 Stitches(That's total 8 Double Crochets made).
Skip 1 Stitch.
Chain 1.
Skip 1 Stitch.
1 Double Crochet in the last 7 stitches.
Step 17:
Round 16:-
Skip 1 Stitch.
Chain 1.
Skip 1 Stitch.
Step 18:
Round 17 Onwards:-
Keep repeating the rounds from *Round 3 to Round 16* untill the size needed.
