Introduction: ٍEasy PCB Cutter With a Grinder on a Chasis
it makes cutting Easy !
The railroad was built with 2 x 2 Iron profiles and it has bearing wheels that move easily back and forth
It is for cutting Plate &Armature screw and of course pcb (electronic board)
- pay attention please................................................................
- If you created this device. When using it. Be careful of the risks for your body.
- It is very hazardous.
Step 1: The System Chasis
Under the system chasis
Step 2: Movers
easy movement by bearing s
Step 3: System Is Completed
it cuts easily
Step 4: Variable Height
Variable height by a screw
If you created this device. When using it. Be careful of the risks for your body. It is very hazardous.
Step 5: It Has Wheel
It has wheel for moving easily
