Introduction: Easy-to-follow Guide on How to Make Wire Wrap Hoop Earrings With Pearls Around
There are a plenty of ways to wrap accessories with wire. A very small gift, like a necklace, a bracelet or earrings, can be diversified and versatile. In this tutorial, you will learn how to wire wrap pair of dangle hoop earrings embellished with some pink and ivory pearls beads for a romantically dream-like look.
Step 1: Supplies Needed for the Wire Wrap Earrings:
8mm Ivory Glass Pearls
6mm Pink Glass Pearls
Handmade Alloy Chains
0.5mm Copper Wire
Earring Hooks
Side Cutting Pliers
Wire Cutter Pliers
Round Nose Pliers
Step 2: Make a Wire and Pearl Hoop Dangle Against Finger
1st, cut a length of 50cm long wire, then wrap it against finger for 4~5 times;
2nd, remove the coils from finger;
3rd, hold the existed coils by another 2~4 new wraps;
4th, string one 8mm ivory pear and fix by making 2~4 wraps;
Step 3: Adding Pearl Beads
5th, add two 6mm pink pearl and fix in place in the same way;
6th, add another groups of one 8mm and two 6mm pearls around the hoop;
Step 4: Deal With the Wire End
7th, keep 6mm wire at end and trim off the excess;
8th, tuck the leftover wire in the first added 8mm pearl bead;
Step 5: Finish the Pearl Beaded Hoops
9th, make another same wire and pearl hoop earring dangle.
Step 6: Prepare the Connective Chain
Find a distinctive handmade alloy chain strand. Remove two units from it.
Step 7: Add the Earring Hook
1st, open the two rings on chain units and hook the dangle. Close the rings then;
2nd, open the loop of earring hook and attach the chain link. Close the loop then.
