Introduction: Eduino WiFi
Eduino WiFi is a DIY Arduino UNO compatible WiFi development board based on the ESP8266EX. I have designed it to teach children soldering, electronics, programming and to build IOT enabled devices.
One design goal was to keep the board as simple as possible to solder. For absolute beginners I pre-assemble the SMT parts.
The board is supported by the ESP8266 project on github: https://github.com/esp8266/Arduino
You can download the project files from here: https://github.com/schirmilabs/Eduino-WiFi
If you want to know more about my work: There is an arcticle from our local newspaper
Features
11 digital input / output pins. All pins support interrupt, PWM, I2C one-wire (except for D0)
1 analog input (3.2V max. Input voltage)
USB B connector
Power supply socket, 6-12 V input voltage
Switching of the supply voltage via two Texas Instruments power-distribution switches (TPS2041 / TPS2051)
Current limitation for both supply voltages (USB / VIn)
Overcurrent display via two red LEDs
PIC 16F1455 as USB microcontroller with official sublicense of USB VID/PID (0x04D8/0xECC6) from Microchip
Reverse polarity protection up to 30V for VIn
Compatible with Arduino
Compatible with NodeMcu
Warning:
All of the IO pins run at 3.3V and are not 5V tolerant
Step 1: Solder U2: TPS 2041
Check orientation!
The gray line on the IC has to be positioned upwards, at the little yellow circle inside of the red enclosed area.
Step 2: Solder U7: TPS2051
Check orientation!
The gray line on the IC has to be positioned upwards at the little yellow circle inside of the red enclosed area.
Step 3: Solder U1: AMS 1117 5.0
Step 4: Solder U6: AMS 1117 3.3
Step 5: Solder R15: Resistor 220 KOhm
Color code is: red, red, black, orange, brown
Step 6: Solder R16: Resistor 100 KOhm
Colour code is:brown, black, black, orange, brown
Step 7: Solder R1, R3, R6, R8, R12, R13, R14, R17, R18: Resistor 10 KOhm
Color code: brown, black, black, red, brown
Step 8: Solder R2, R4, R5, R7, R9, R10, R11: Resistor 1 KOhm
Color code:brown, black, black, brown, brown
Step 9: Solder C1, C3, C5, C7, C8, C10, C12: Capacitor 100 NF
Step 10: Solder D2: Diode 1N5819
Check polarity !
The gray marking has to be positioned upwards.
Step 11: Solder D1: Z-Diode ZPD 5.1
Check polarity !
The black marking has to be positioned on the left side
Step 12: Solder D4: Diode 1N4148
Check polarity !
The black marking hast to be positioned on the right side
Step 13: Solder D3: Z-Diode ZPD 3.3
Check polarity !
The black marking has to be positioned upwards.
Step 14: Solder L1: Ferrit Bead
Step 15: Solder U4: IC Socket 14 Pins
Check orientation !
The notch on the socket has to match the notch as stenciled on the board.
Step 16: Solder LED4 and LED5: LED 3mm Red
Check polarity !
The long leg has to be positioned on the left side (+ sign on the board )
Step 17: Solder LED1 and LED2: LED 3mm Yellow
Check polarity !
Step 18: Solder LED3: LED 3mm Green
Check polarity !
Step 19: Solder SW1: Tact Switch 3x6
Step 20: Solder T1 and T2: Transistor BC 547
The straight edge of the Transistor should match the straight edge of the stencil.
The middle pin has to be bent backwards before assembly.
Step 21: Solder C4 and C6: Electrolytic Capacitor 47 UF
Check polarity !
The long leg has to be positioned downwards (+sign on the board)
Step 22: Solder C2 and C9: Electrolytic Capacitor 10 UF
Check polarity !
The long leg has to be positioned on the left side at C2 (+sign on the board) and downwards at C9 (+sign on the board)
Step 23: Solder X1: DC Power Jack
Step 24: Solder X2: USB Type B Connector
Step 25: Short Circuit Check
Check the bottom side for possible soldering short circuits
Step 26: Power Supply Check
Connect the board with a PC or a USB charger via a USB-B cable.
The green LED should light up now.
Step 27: Solder Power: Female Header 8 Pins
Step 28: Short Circuit Test
Connect GND and +5V with a jumper wire cable
Then connect the board with a PC or a USB charger via a USB-B cable. The red LED on top should light up now (Overcurrent indicator)
Step 29: Solder U3: ESP-12 Module
Step 30: AD: Female Header 6 Pins
Step 31: Solder IOL: Female Header 8 Pins
Step 32: Solder IOH: Female Header 10 Pins
Step 33: Solder C11: Electrolytic Capacitor 100uF
Check polarity !
Step 34: Mount PIC 16F1455
The IC has to be mounted carefully, with the notch in the IC matching the notch in the socket.
Step 35: Boards Availablity
If anyone would like a board, it is already shared on PCBWay:
