Introduction: Eggs in a Window
This is a very easy dish to make that has very few ingredients, and can be taken with you and eaten on your commute to work in the mornings. I used to make this for my son when he was a little boy over a decade and a half ago, and had forgotten about it until just recently when, as much as I hate to admit it, started missing him. He's flown out of the nest and has gone away to college to become an electrical engineer (or so he says now).
Step 1: Ingredients...
The ingredients are your basics:
Bread
Eggs
Margarine, Butter or Vegetable Oil
Spices (Salt, Pepper, Garlic, your choice here)
You'll need a heat source, such as a stove, and a frying pan large enough to hold the slice of bread that you'll be using. A tight fitting lid helps the cooking time along, but is not necessary.
You will also need to cut or make a hole in the middle of your bread slice. A cookie cutter works great here, and you can make fun shapes with them. I have chosen to use a penguin shape for this instructable. If you don't have cookie cutters, just use a knife to cut a shape out of the center of your bread slice. This can be a circle, a square, a triangle, a heart, a star, a rhombus, a hexagon, a decagon... you get the idea.
Step 2: Make Your Window...
Place the cookie cutter on your slice of favorite type of bread and press down firmly on the cookie cutter, using a flat surface underneath your bread slice (cutting board or counter top). Flip the slice of bread over. When you see all of the cutting edge from the opposite side, remove the cookie cutter and it's cut out piece. Place the cut out piece to the side and decide what you want to do with it later. I usually throw it at the dog (she'll catch it and swallow it all in one motion), fly it in the back yard for the birds or fry it up in the pan with the left over butter and spices.
Step 3: Time to Start Cooking...
Pre-heat your pan on medium low heat. Place your choice of oil (I use butter) in the pre-heated pan and swirl it around, coating the bottom. Add the slice of bread and slide it all over the pan, trying to get all the oil into the bread. This helps the browning process.
Crack an egg into the center of your bread slice, or "window" cut out. If you want, you can scramble your egg before this step, or eliminate the yoke if that is your thing, then pour it into the "window".
Add whatever spices you desire. I keep it simple and just use salt, pepper and garlic powder, but feel free to use whatever seasoning you like.
Cover the pan with a lid. This helps to cook the top of the egg a little and helps when it comes time to flip the slice of bread over.
You guessed it. When the bread is starting to brown up and the egg is about half way cooked, flip it over and continue cooking until your desired doneness.
I like my yokes semi-cooked so that I can pick up the slice of bread and eat it as opposed to using utensils.
Step 4: Ta Da! Egg in a Window.
Eat and enjoy.
Step 5: Hi, My Name Is Bert, What's Yours?
... Looking good...
