Introduction: Electric Foot Warmer
Welcome to this Instructable on how to make an electric foot warmer. Today, I will be instructing you on how to construct this warmer from reusable or common materials through using induction heating as the source of this warmth. With that being said, you can start your journey below by gathering the materials and getting ready to create your own!
  • Foam Board/Posterboard/Wood (I used foam board with a wood backing for stability and softness)
  • Optional: Glass or Copper Sheet
  • Nichrome Wire
  • 12V regulated power supply
  • 12V power supply connector
  • Soldering Iron with Solder
  • Connecting Copper Wire
  • Cardboard
  • Box Cutter/Xact-o Knife
  • Duct Tape or Cloth
  • Hot Glue Gun and Hot Glue
Step 1: Tracing the Feet
  1. Take a pair of sandals or slippers and trace out the feet shape on your posterboard/foam board/wood
  2. Ensure that your feet will fit in the space and take a small knife and cut a bit into the trace for the cardboard slots later
  3. If the posterboard is too large, cut it down to a size that will fit under your desk or for portable use, my cutout was fitted for under my desk, where I use it most frequently, which is around 18 inches and 20 inches
Step 2: Laying Out Nichrome Wire
  • Take your nichrome wire, leave an extra 4-5 inches and start laying them down into the traced shape in vertical lines. For this design, I had 8 vertical lines on either foot space
  • Start to use one piece of tape for every strand and go up as you do, with the first piece starting at bottom, and the last piece being near the top. By the end, the rape should be in a diagonal pattern
  • Once you have 8 lines, start to lay the wire horizontally and continue to make lines
  • However, when you are doing this, make sure you tape down the overlapping places so the metal wires do not explicitly touch each other (this can cause heating issues that will result in high concentrating of heat that will result in less heat distribution)
  • Once you finish one foot, do not cut the nichrome wire, just continue with the existing strand and do the same process that you did for the first foot, and then leave 4-5 inches after you finish the process and then cut the strand off.
  • In the end, you should have covered both feet, have two hanging strands that we will solder, and have a connecting piece between the two feet
Step 3: Adding the Cardboard Edges
  • Cut out 6 feet of cardboard that is 1 inch in depth
  • I cut the 6 feet into 6 pieces of 1 foot each and applies 3 feet worth of cardboard for either feet
  • Start outlining the edges of the feet with hot glue and add each of the pieces on by one, shaping it with your fingers and holding it in place until it dries - insert each piece into the small cutout you made earlier so it helps it remain in shape
  • By the end, you should have an outline like the one pictured above, with places to put your feet
Step 4: Soldering the Power Supply Connector
  • Take a 12V power supply port and find the two metal ends on the port that you can establish an electrical connection to.
  • We are induction heating so we need a complete circuit where the electricity can travel through the wire and return to heat it
  • Solder one wire from each of the feet to either one of the ends on the power supply port and then you should have established your connection.
  • You can glue the port to the posterboard/foam board/wood that you have
Step 5: Finishing Touches
Some optional changes or additional you can make include adding duct tape layers on top of the wire so you can feel the heat without having to feel your feet jostling the metal or concentrated heat regions or adding cloth on top if you want a more plush and blanket-like feeling for your feet as it heats.
Additionally, I added a small wooden sheet below the foam board that I used so that it does not collapse under the pressure of my feet or fold and that it is able to remain a solid structure. I used a thin layer of wood to do this as well in order to maintain its portability and its ease of carrying as it is not too heavy.
With these changes, your induction heated foot heater is now complete! You can take this wherever you go and use it however you like, just make sure to have your power supply with you and plugged in to supply the heat and within a few seconds you should feel it heating up and supplying you with the warmth that we all cherish in the fall and winter months.
