Introduction: Electric Slide
To perform the Electric Slide, you only need the urge to dance and the music, which can be found at this link: http://www.youtube.com/watch?v=JFMtBibwrgY.
Follow the instructions to learn the basic steps.
Step 1: 4 Side Steps to the Right
Take four side steps to your right, beginning with your right foot: step right, left together; step right, left together.
Step 2: 4 Side Steps to the Left
Take four side steps to your left, beginning with your left foot: step left, right together; step left, right together.
Step 3: 2 Steps to the Back
Take two steps to the back (remain facing forward), beginning with your right foot: back right, left together.
Step 4: 3 Step-touch
Step back onto your right foot. Tap your left foot in place.
Step forward onto your left foot. Tap your right foot in place behind you.
Step back onto your right foot. Tap your left foot in front of you.
Step 5: Pivot and Brush
Put your weight on your left foot and pivot 90 degrees to the left on your foot. At the same time that you pivot, brush your right foot into the air. When you land on your right foot, this will be the first side step of step number 1. You will now prepare to:
Step 6: REPEAT!!
Repeat (1) through (5) as many times as desired. Note: For each repetition, you will rotate 90 degrees to face a different wall.
Step 7: 7) “Add Your Jazz”
There are many ways to perform the Electric Slide. As long as you follow the basic steps described above, you can add whatever style and savoir-faire you desire. Some people choose to alter (1) and (2) into a grapevine by passing the foot that closes under the body behind the standing foot. Other examples of adding your jazz include clapping or snapping at strategic moments. Don't be afraid to try adding something new.
The dance can also be performed with a group of friends by lining up side by side.
