Introduction: Energy Saver 3000
Adrien Green, Huy Tran, Jody Walker
The use of a Raspberry Pi computer and Matlab is a simple and effective way to help homeowners reduce there energy consumption. The best part about the Energy Saver 3000 is that it is very simple to set up and use. The main purpose of the Energy Saver 3000 is to allow homeowners to be able to track their energy bill to see how much they're spending, and to allow home owners to turn off the lights in there homes remotely with a press of a button.
Step 1: Parts Used
1: Raspberry Pi computer
2: Breadboard
3: Jumper wires
4: Push button
5: Mini LED lights
6: 330 ohm, 10 Kohm, and a 300 ohm resistor
7: Ethernet Cable
8: Light photocell
Step 2: Problem Statement
Our project was to design a home energy saver using a Raspberry Pi computer and MATLAB. Our goal was to build a system that allowed users to track their energy bill to see if they can reduce their energy consumption. We also wanted users to be able to turn off their lights while they were gone with a press of a button. To do this, we wired up a photocell to sense when the lights are on. If the lights are on, the MATLAB program will calculate how long they've been on and how much energy and money has been spent since they've been on.
Step 3: Setup
Wire up the breadboard as shown in the Picture above.
Step 4: MATLAB Code for Controlling the Photocell
function control_light()
rpi = raspi();
writeDigitalPin(rpi,12,1)
time = 0
sumcost = 0
Time = 0
Cost = 0
bulb = 100/1000;% kilowatts
for i = 1:2
tic
while true
x = readDigitalPin(rpi,13)
if x == 1
writeDigitalPin(rpi,19,1)
elseif x == 0
writeDigitalPin(rpi,19,0)
toc;
time = time + toc
kwh = toc * bulb
dollars = 0.101
cost = kwh * dollars
sumcost = sumcost + cost
X = linspace(Time,time,10)
Y = linspace(Cost,sumcost,10)
Time = time
Cost = sumcost
disp(['Light has been on for ', num2str(toc),' hours. Cost = $', num2str(cost)])
plot(X,Y,'b') title('Cost Over Time')
xlabel('Time (Hours)')
ylabel('Cost ($Dollars)')
hold on
break
end
end
pause(5)
tic
while true
if x == 1
elseif x == 0
toc;
time = Time + toc
kwh = toc * bulb
dollars = 0.101
sumcost = Cost + cost
Time = time
Cost = sumcost
plot(X,Y,'g')
hold on
break
end
end
pause(5)
end
Step 5: MATLAB Code for Turning Lights Off
function button_controlv1()
rpi = raspi();
condi = 1;
while true % creates an infinite loop to keep the code running
button = readDigitalPin(rpi, 6); % Reads the button press value on pin 6
if button == 0
condi = condi + 1
end
if mod(condi,2) == 0
writeDigitalPin(rpi,17,0)
h = msgbox('You turned the light off. :)') waitfor(h);
break
end
if mod(condi,2) == 1
writeDigitalPin(rpi,17,1)
end
end
Step 6: MATLAB Code for Turning Lights On
function button_controlv2()
rpi = raspi();
condi = 2;
if button == 0
condi = condi + 1
end
end
h = msgbox('You turned the light on. :(')
waitfor(h);
pause(10)
break
end
end
Step 7: MATLAB Code for GUI
function EnergySaver3000()
imgurl='http://clipart-library.com/images/pc585dj9i.jpg';
imgfile='Lightbulb.jpg'; urlwrite(imgurl,imgfile);
imgdata= imread(imgfile);
h=msgbox('Welcome to the Energy Saver 3000!','','custom',imgdata);
waitfor(h);
clear h;
while true
iprogram=menu('Which Program Do You Want to Run?','Bill Calculator','Light Control');
if iprogram==1
control_light() h=msgbox('Done!!!')
close all
elseif
iprogram==2
end
clear h;
ichoice=menu('Light Control','Turn On','Turn Off','Nevermind');
if ichoice == 1
button_controlv2()
h=msgbox('Done!!!')
elseif ichoice ==2
button_controlv1()
h=msgbox('Done!!!')
elseif ichoice==3
h=msgbox('You did nothing :(') waitfor(h);
h=msgbox('Done!!!')
end
waitfor(h);
end
end
