Introduction: Fancy Paper Bag
Welcome! Interested to make this Easy to make Paper Bag. Follow the steps as listed. Hope you get the end result just like the Final Image. :)
Step 1: Material Gathering
1. Paper
2. Scale/Measuring Tape
3. Fancy Scissors
4. Paper Cutter
5. Marking Pencil
6. Glue
7. Cloth Glue
8. Ribbon
9. Hole Punch
10. Hole Guard
Step 2:
Measure paper.
Step 3:
Divide paper in 3 parts.
Step 4:
Fold each paper in 3 portion as shown above.
Step 5:
Now mark an angle of 60 degrees as shown.
Step 6:
Follow the previous step. Please keep in mind about the open and close sides.
Step 7:
As shown in the image, cut both the papers accordingly.
Step 8:
It will look like this after the cutting process.
Step 9:
Same as previous.
Step 10:
Open and flatten both papers.
Step 11:
Fold the paper(colored side on the inside as shown in the image) and cut with fancy scissor.
Note- Here I have selected only the pink color paper to cut. Hence when you do so, do consider cutting only 1 paper for this step only.
Step 12:
Open and flatten both paper.
Step 13:
As shown in the above image, mark the area and apply glue on the marked area.
Step 14:
Apply glue on the marked area and paste them together and later it will look like the above image.
Step 15:
Now turn the paper over. Colored side will be on the top.
Step 16:
Cut strip like the image above.
Step 17:
Stick the paper as shown in the image and the lemon yellow paper as per my example should be overlapped.
Follow the image.
Step 18:
The result of the previous step.
Turn the page so that the white side will be on the top.
Step 19:
Fold perfectly on the line shown by the tip of the scale.
Step 20:
Turn over again. The paper is ready to be made in a paper bag.
Step 21:
Step 22:
Follow the instructions in the above image and fold accordingly.
Step 23:
Stick as per the image.
Step 24:
As per the image, fold accordingly.
Step 25:
Apply glue on the white strip and fold it upwards.
Step 26:
Punch holes and secure with Hole Guard.
Step 27: Fancy Gift Bag Made From Waste.
As shown in the image, add ribbon as a handle and stick some leftover pieces from the paper and make your own design.
Bag Ready.
Step 28:
Some different type of bags.
