Introduction: First Attempt at an Electric Guitar
I've wanted to build an electric guitar for a long time and this summer I took the initiative to do so.
My uncle does a lot of wood work and sent me a blank of swamp ash. I took my initial guitar design, redesigned it so the scoop was on the right side, then set about building the body.
I imported my drawing into SolidWorks and made an outline which I had printed from Staples. I wanted part of the body raised so I started by outlining the guitar and milling everything except that section down.
I used some Power Grip hand tools and a Denker carving shave tool to get the curvature right on the raised portion.
From there I made another outline and started cutting the body out. I got the band saw blade stuck in the wood and decided to make some cuts perpendicular to the outline so that once the blade passed a certain point it would just break away. I used a scroll saw to get the tighter sections.
I used some double sided tape to attach sand paper to a circular saw bit to get at the parts the belt sander couldn't, as well as hand files. Then I used the Power Grips and Denker again to shape the cutaways.
There were a couple spots that either chipped or I had taken too much material from so I got a piece of left-over swamp ash, put it on the belt sander, collected the saw dust, and added some wood glue to make a putty and filled in where needed. Thanks to BrendanMH for the idea!
The neck was purchased from Stewart MacDonald (www.stewmac.com).
I am currently sanding the entire body down with 80, 150, 320, and 600 grit sand paper.
UPDATE 10/24/13:
The body shape is just about finished, I just have to sand down a couple last spots and it's ready for pockets!
I've added three pictures from early October and 4 pictures that aren't the most recent progress, but close to it. More to come.
