Introduction: Fishtail Rainbow Loom Bracelet Tutorial
In this tutorial, I will show u how to make an easy Fishtail Rainbow Loom Bracelet.
Here is the bracelet we will be making
Step 1: Materials
Material:
A metal hook
A mini loom
2 x rubber bands colors (pink and green). You can use any colors you want. For each color I use around 18 rubber bands.
C-clip (you can also use S-clip)
Step 2: Add First 3 Bands
Add first pink rubber band and twisted
Next loop a green band
then loop a pink band
Step 3: Unhook Bottom Pink Band
Unhook bottom pink band one end to the top
Do the same for the other end
Step 4: Add Next Green Band
Loop a green band
Unhook the bottom band (green) to the top
Step 5: Repeat the Pattern
Add next band, which is pink color
Unhook bottom band to top
Alternate color for each loop
Step 6: Transfer Bracelet Into Hook
Your bracelet should look something like this
Unhook one end all rubber bands
Slide hook under the other end rubber bands, unhook it and slip into finger
Step 7: Add Clip to Rubber Bands
Unhook all the rubber bands and hook into one end of C or S clip
Hook the other end of clip to the other end of bracelet
Step 8: Result
You should have a Fishtail bracelet as show
I hope this tutorial is helpful to you..
Please check out my Youtube video for bracelet making process.
