Introduction: Fix a Broken Bed Frame (DIY)
This is a very old bed frame that is broken and I think It can still be fixed by spending a little bit of money. It looks like a DIY solution is possible with the available parts that I can use.
Step 1:
  1. You need to ready your angle bar and create a screw wholes in advance, it is important that after the applying the glue you then mount the wooden cross beam and screw the angle bar to support the wooden beam.
  2. Apply the wood glue and make sure it is secured and will not move.
  3. Install the angle bar and screw in according to the wholes that is pre-made. Make sure the angle bar is secured.
  4. Allow the glue to cure and install the supporting legs so that there is a support in the center of the bed frame for additional sturdiness.
